No Flow!
Old Dec 5, 2009 | 06:45 PM
crsdon's Avatar
crsdon
4th Gear
Default No Flow!
I've replaced the thermostat (checked before installation) and the water pump in my '02 and still have no flow( top rad hose is cold/no warm air from heater) and I'm overheating rapidly. I obviously still have a blockage somewhere, but thermostat and water pump channels were clean as a whistle. Any ideas??
Old Dec 5, 2009 | 06:52 PM
lucky131969's Avatar
lucky131969
Have to be a pretty serious obstruction.....if the thermostat is opening...the water pump may shot.
Old Dec 5, 2009 | 07:14 PM
crsdon's Avatar
crsdon
4th Gear
I've replaced both the thermostat AND the water pump. I checked the themostat before installation..
Old Dec 5, 2009 | 07:15 PM
Oaf02Z's Avatar
Oaf02Z
i had the same problem, i put 2 thermostats on and replaced the water pump and it was still over heating in minutes. Make sure you get all the air out of the coolant system. All i had was a big air bubble. As soon as i got all the air out, coolant got through and my car has stayed cool ever since. Good luck i know its a huge headache, this happened to me 2 weeks after i bought my Z.
Old Dec 5, 2009 | 07:31 PM
lucky131969
Ok. I'm also assuming that you have followed the coolant filling procedure....
Old Dec 5, 2009 | 07:33 PM
SpeedyGjr's Avatar
SpeedyGjr
It's air bound. Raise the front of the car a high as you could get it while running with the cap off & you should see bubbles!
To No Flow!
