Rear tire clearance issue
Old Dec 7, 2009 | 05:19 PM
Sinister-one's Avatar
Sinister-one
Default Rear tire clearance issue
I just installed a set of C6 Z06 style wheels on my FRC. I went with 325-30-19 in the rear. the tire shop installed a set of 1/4" spacers and now the tires stick out slightly past the fender.
I checked the car when I got home and it feels like there's more than a 1/4" in clearance from the tire to the inner wheel well.
Did i choose the wrong size tire ?
Old Dec 7, 2009 | 05:38 PM
99vetteran's Avatar
99vetteran
Its probably the wheel since you had to put a spacer on it. The 325 is not that tall a tire, but, the wheels on the c6 have different backspace then the c5's. I'm assuming they spaced because you didn't have clearance on the inside. Are the wheels 10.5 inches or 12 like the zo6? I put c6 style wheels on mine that are 10.5 wide with no problems, however I didn't put a 19 on it, mine are 18's. The tire could also be part of it as the 325 is pretty dam wide for sure. Its a combination of both. You could have probably done ok with a 295-35-19 and had less of an issue.
Old Dec 7, 2009 | 07:14 PM
Sinister-one
The wheels are made with C5 offsets. They are 19x11's Looks like I may have to start looking for 295's or 285's.
Old Dec 7, 2009 | 10:00 PM
99vetteran's Avatar
99vetteran
Do you have any pics to post? I'm looking at maybe doing a 19 on the rear, but, they are only 10 wide. I need the 18x10.5 I now have on there for my 315-35-18 drag radials. I want to have the tire tuck a little more and I may try to run a 275-40-19 for the pro touring look. They are 27.7 tall which is 1 inch taller then the 275-40-18's. I'm still a little undecided at this point. Good luck whatever you decide to do.
Old Dec 7, 2009 | 10:12 PM
Indy's Avatar
Indy
Why not take the spacers out and check for clearance...only way to know for sure. Indy
Old Dec 7, 2009 | 10:21 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
You've got room - You can squeeze 335/30-18s out back on the C5Z, and we have brake cooling ducts in the way. What's the offset of the C6Z wheel you're running?
Old Dec 7, 2009 | 10:27 PM
Its_Go_Time's Avatar
Its_Go_Time
Ur sayin that you can fit a 335 on a C5 Z06 without removing the brake ducts?
Sinister, what offset are your wheels?
Old Dec 7, 2009 | 10:31 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
Done it 3 times, personally. I used to work for Fikse and, while there, devised an offset that worked just right.
Old Dec 7, 2009 | 10:42 PM
Sinister-one
I'll be doing just that this coming Saturday.
Not sure on the offset. I'll have to ask the previous owner of the wheels.
Old Dec 9, 2009 | 02:53 PM
Sinister-one
Okay now that this problem may be solved....
With 325-30-19 in the rear, what size tires should i have up front ?? 245-40-18 ??
Old Dec 9, 2009 | 03:32 PM
99vetteran's Avatar
99vetteran
That should be about right, but, I'd consider a 255-40-18 which is 26.0 tall where the
245-40-18 is 25.7. The 255 would fit on the 18x9.5 rim a little better then the 245. Either would look proportionate to rear whick is 26.7 tall. Good luck
Old Dec 9, 2009 | 03:51 PM
Sinister-one
255's it is !!
Thanks 99vetteran.
Old Dec 9, 2009 | 03:52 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
Whoa, whoa... What size are the wheels? 9.5 X 18, right? If so, you need to go 275/35-18.
Old Dec 9, 2009 | 03:58 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
255's it is !!
Thanks 99vetteran.
A 255/40 on a 9.5 X 18 is going to be stretched to reach the bead while the 325/30 on the 11.0 X 19 is going to have a slight bulging effect... If you do a 275/35 on the 9.5 X 18, it will be a square fitment and look a lot more like the rear arrangement.
Old Dec 9, 2009 | 04:04 PM
Sinister-one
Okay..... right now I've got 275 40 18's on the front now and when I turn the wheels right or left most of the way i can hear them rub on the inner fender wells. Will I have this same problem with the 275/35's ??
And yes my front wheels are 18x9.5's.
Old Dec 9, 2009 | 04:15 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
You shouldn't... That's a tall tire you're running up front buddy! Actually doesn't surprise me that it rubs. A 275/35 is about 1" shorter in diameter - TONS of people run this size on the front of their C5. You have any idea what the offset of your front wheel is?
Old Dec 9, 2009 | 04:31 PM
99vetteran's Avatar
99vetteran
The 255 calls for 8.5 to 10.0 and would be fine if you choose to use that tire. I think he also said his car is lowered. So much depends on the offset of the wheels as to the clearance you have. I don't know the offsets so its hard to gauge on the 275-35-18 has a section width of 10.9 and the 255 has a section width of 10.2. I don't like to see the sidewall stretched either and the 245-40 he originally spoke of would stretch the sidewall and 255 wouldn't have the same issues. I'm trying to keep him in the safety zone so he doesn't have to continue to change tires. If you don't have it lowered you are probably ok with the 275, I don't know if it would rub on a lowered c5 or not. I'm guessing it might. Your choice.
To Rear tire clearance issue
Old Dec 9, 2009 | 04:43 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
Originally Posted by 99vetteran
The 255 calls for 8.5 to 10.0 and would be fine you choose to use that tire. I think he also said his car is lowered. So much depends on the offset of the wheels as to the clearance you have. I don't know the offsets so its hard to gauge on the 275-35-18 has a section width of 10.9 and the 255 has a section width of 10.2. I don't like to see the sidewall stretched either and the 245-40 he originally spoke of would stretch the sidewall and 255 wouldn't have the same issues.
No offense man, but I used to do this for a living - I was the Fikse wheel rep/tech for Ford Racing, Chip Ganassi Racing, Riley... I actually even devised the fitment for the first 2009 Camaro Koni car. I know what I'm talking about. Anyways, I digress...
A 255/40-18 isn't a correct fitment for a 9.5 X 18. Will it work? Sure... But it will be a very convex fitment. On a 9.5 X 18 wheel, you should run at least a 265/35-18. A 255/40-18 is meant for a 8.5-9.0" wheel. If you're that concerned about rubbing, and the car is that slammed, go with a 265/35-18. But that's as narrow as you should go with a 9.5" wheel.
Old Dec 9, 2009 | 04:45 PM
Sinister-one
I'll find out what then offsets are from the previous owner of the wheels. And yes the 275/40's are TALL !! And from the rubbing, I think they're to tall and to wide.
The 255 calls for 8.5 to 10.0 and would be fine you choose to use that tire. I think he also said his car is lowered. So much depends on the offset of the wheels as to the clearance you have. I don't know the offsets so its hard to gauge on the 275-35-18 has a section width of 10.9 and the 255 has a section width of 10.2. I don't like to see the sidewall stretched either and the 245-40 he originally spoke of would stretch the sidewall and 255 wouldn't have the same issues. I'm trying to keep him in the safety zone so he doesn't have to continue to change tires. If you don't have it lowered you are probably ok with the 275, I don't know if it would rub on a lowered c5 or not. I'm guessing it might. Your choice.
Thanks for your post 99.... My car isn't lowered, yet. I may be looking to lower it about 1" inch or so, not all the way. But then again, these cars sit low enough as it is.
Old Dec 9, 2009 | 04:50 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
Go with a 275/35... If it rubs, either your wheel has more than +57mm offset and isn't meant to go on your car, you have a narrower track width than a normal C5, or your camber is way off. That's the last thing I'm going to say about this. Good luck Sinister...
