NX TPAS install question
Old Mar 1, 2002 | 09:43 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
Default NX TPAS install question
When you guys hooked up your TPAS, did you run your input wire way over to the TPS sensor and splice there? Or is there another place you can pick it up closer to the battery area? maybe out of the pcm?
TIA,
Eric
Old Mar 1, 2002 | 09:53 PM
C5Noir's Avatar
C5Noir
Default Re: NX TPAS install question (91ZR1)
Yep, you have to splice in there at the TPS connector (blue wire on the passenger side of throttle body).
Old Mar 2, 2002 | 01:29 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
I kept the NX switch inside the car and run another long wire through the firewall to tap into the TB wire harness. You definitely don't want to expose this switch to extreme heat under the hood. It is the last thing you want to fail.
-Tuan
To NX TPAS install question
