wideband-sensor.. where may i put it
Old Dec 11, 2009 | 05:57 PM
baezi z06's Avatar
baezi z06
Default wideband-sensor.. where may i put it
hi
can i put the wideband sensor into the rear O2 sensor pung on the the exhaust, or needs it to be near the front O2.
i´m not using the rear sensors, so it would be good if i could just installe it there, so i wouldn´t have to do any mods to the exhaust to installe a exhaust pung.
i´m using NGK Afx.
thanks
Baezi
Old Dec 11, 2009 | 07:07 PM
Its_Go_Time's Avatar
Its_Go_Time
Do you still have your catalytic converters? If yes, then no. If no, then maybe. The further you get from the engine, the cooler the sensors run. If they run too cool, they may not work properly. My LG headers/ x-pipe with cats puts the rear sensors so far back that they never worked properly. I don't know if this was due to the lower temps, or the less efficient "high flow" cats, but I had to tune them out and forget about them. Depending on the controller you use, you can put the sensor up front and have it provide two signals: a narrow band signal for the PCM, and a wide band signal for yourself.
Old Dec 12, 2009 | 03:53 AM
baezi z06's Avatar
baezi z06
no cats, i´m running kooks Xpipe offroad., i was reading the NGK´s install instructions , and the sensor needs to be in the 12" to 48" range from the engine, i just have to measure that to know it.
thanks
Baezi
Old Dec 12, 2009 | 09:45 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I installed my widband sensor as clse to the engine as I could. Here is my X-Pipe:
You need to have the bung welded in on the left side, angled slightly up, to keep moisture out of it. The left side will monitor Cylinder #7, which is the worst to run lean.
Old Feb 21, 2010 | 12:04 PM
Higgs Boson's Avatar
Higgs Boson
How do you route the wire into the vehicle?
Old Feb 21, 2010 | 12:27 PM
clif's Avatar
clif
You remo ve the tunnel plate, then drill a very small hole in front of the ash tray (after the console is removed, of course). That is how I ran mine anyway. There are other methods, but this worked for me.
Old Feb 22, 2010 | 04:43 AM
baezi z06's Avatar
baezi z06
i went whith rear sensors holes, and it´s working fine, it´s well whith in the 48" range from the engine.... so.
i tooke the wires front to the batteri where i got Voltage and then into the car and under the carpets. my meter is below the key-switch.
Baezi
Old Feb 22, 2010 | 08:21 AM
RobertEarl's Avatar
RobertEarl
Most all of the widebands will also emulate a narrow band. Just replace the front O2 sensor with the wideband and hook the other wires that emulate the narrow band back to your engine harness. I have been running my LC1 that way for almost two years.
Reb
Old Feb 22, 2010 | 08:27 AM
clemsondave's Avatar
clemsondave
I would not do that, you'll only get readings from one side if you put it before the X. To get proper readings on both sides, go with Clif's suggestion above. Exactly where mine is.
Old Feb 22, 2010 | 08:44 AM
baezi z06's Avatar
baezi z06
yes i agree there,
i used to runne the wideband beside the driverside front sensor, but now after i got bigger headers i decided to have it right after the Xpipe in one of the rear sensors cap. and it´s working fine.
now the readings is from both sides i would think...
Baezi
Old Feb 22, 2010 | 08:47 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Wideband must be as close as POSSIBLE to the #7 cylinder inorder to give the MOST accurate readings - #7 is the one cylinder that will have the highest potential for a lean condition
Here are a couple of pictures of where mine is located on the Drivers Side closest to the #7 pipe on the Kooks Headers: I also use the AFX Wideband-
Thanks,Matt
To wideband-sensor.. where may i put it
