Paintjob chipping
Old Dec 11, 2009 | 11:18 PM
rsxmanjoe's Avatar
rsxmanjoe
Default Paintjob chipping
So I had my bumper on my 02 z repainted after alot of bottoming out....so today I pulled into a parking spot and happened to rub the curb as I pulled in a little too far. No biggie, it usually comes right off, and at the very worst Ill use some rubbing compound to remove it. So I take a look when I get home and notice my paint is chipping off! Yes it was like the bumper was spraypainted! What kind of paint is this? Color wise it matches perfectly but apparently they didn't add a flex additive to the mix? Im very angry and will be going down to the ****ty shop tomorrow to let them know
Old Dec 11, 2009 | 11:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yeah, even after doing this multiple times, I'm still unable to control my car well enough to avoid colliding with other fixed objects that will certainly damage my paint....it must be the painter's fault.
Best of luck finding any painter in the world that warranties damage caused by collision.
Old Dec 12, 2009 | 12:05 AM
rsxmanjoe's Avatar
rsxmanjoe
i guess you've never pulled into a parking spot and parked slightly too far over the curb? i mean we are driving corvettes here.....
its obvious that it was painted without a flex-additive. unacceptable
Old Dec 12, 2009 | 12:24 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Mine wouldn't come close to going OVER a curb...It barely clears my foot.
So Yes, we're talking Vettes, and yes I did hit a curb once....then I learned it's better to stop short, then wait for that awful noise to tell me I should've stopped sooner.
If there was no flex agent in the paint on your front bumper, the entire surface of it would be hairline cracked and checked by now, just from fluctuations in temperature.
New paint is quite fragile, and takes quite a while to be fully cured and bonded to the base surface. You learned this the hard way, but by no means is it the fault of the painter.
Learn how to stop short of curbs, and it'll save you a lot of money.
Old Dec 12, 2009 | 12:31 AM
rsxmanjoe's Avatar
rsxmanjoe
I do stop short 99% of the time - maybe your car is a garage queen but I actually drive the car ALOT - this was the first curb I went slightly over since I got it painted 6 months ago - lol I guess your the perfect driver or your car collects dust all day
Theres no logic to paint chipping off like that...what happened here then if the job was done properly? Ive never had paint "chip" off in big pieces like this - usually going over the bumper would lead to a couple scratches that could be taken off with a rubbing compound....let me know since you're apparently a corvette wiz
Old Dec 12, 2009 | 12:50 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
If it was painted 6 months ago, and flaked off in a big piece upon contact, it tells me either you scraped it off at the perfect height/angle, or the base surface was insufficiently prepped.
But regardless of that, the paint would still be intact had you not run into anything. (the very point that will get you nowhere with the painter)
I've owned my car over 7 years, and have put about 60k miles on it. It's stored for winter, sure, but that's life in WI. Many others here can attest to my cross country travels and the fact the car is driven.
That's not the point though...Just because you feel you have more opportunities to damage your car, doesn't mean you should take advantage of them. More practice driving and parking should make you more aware of the car's position.
It only took me once to learn....
Old Dec 12, 2009 | 01:04 AM
rsxmanjoe's Avatar
rsxmanjoe
well yes but when I got it painted I was also under the assumption that the paint wouldn't flake if I came in contact with the slightest object. The original paint I had on the bumper was when the car was lower and I bottomed out all over the place and never had the paint flake off like that. Like you just said above, it was most likely bad prep work that caused this situation, not something I should be responsible for. Had he told me that the prepwork would be faulty prior to painting the bumper and I agreed, then you would be correct. Pretty easy concept to grasp
I'll work on my driving and you work on your reading comprehension
Old Dec 12, 2009 | 01:53 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
My comprehension is just fine, and my first reply stands...If your painter warranties his paintwork in the event of collision, you should be all set.
That's the bottom line. You didn't mention any complaints with the paint prior to collision.
Old Dec 12, 2009 | 02:43 AM
kg54trains's Avatar
kg54trains
If you are getting batches of paint peel then the shop did a "Macco" paint job that looks good for a few months but will start to peel because preparation prior to the spray was not completed or the shop did not use a flex additive that is used on all bumper finishes. Costs are a factor because you get what you pay for in any paint job
Happy holidays to all.
Old Dec 12, 2009 | 08:27 AM
dougbfresh's Avatar
dougbfresh
I don't believe you have to use flex agent much anymore with real urethane paints (which I'm "assuming" is what they used), the problem is probably adhesion with the old paint. If the bumper was intact before the paint job, they probably just scuffed it with a 3M pad and shot right over the old color with little or no priming would be my guess.
I left some Urethane in a mixing cup not too long ago and when the hardening was done it was like a huge chunk of Jello. Either way, I doubt he'll warantee this since you ran into something.
Old Dec 12, 2009 | 10:18 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
sounds like they didn't prep the part properly when they re-painted it. or, didn't use the right type of primer. i haven't read the rest of the thread but i'll guess someone has said something about using a flex-agent, blah blah blah. i work for a plant that produced over 5 million painted plastic pieces lats year, for every OEM car mfg in north america. we have never bought an ounce of flex agent and never had a part come back for a warranty claim that was deemed our fault.
it all comes down to prep and using high quality paint. i've seen a couple of shops just use some kind of rubbing compound crap on top of existing paint then paint right over it. looks fine for a few months..then falls right off.
Old Dec 12, 2009 | 11:55 AM
bobby777's Avatar
bobby777
Grab a can of "Close Match" paint and have at it-
Old Dec 12, 2009 | 01:36 PM
Tech's Avatar
Tech
Y2Kvert4me is right. You damaged the bumper before you were aware of a paint problem. It's a crappy situation you're in, but most body shops aren't going to repaint that bumper after you've damaged it.
BTW, I have daily driven mine in rain and snow and have never hit a curb. Accidents happen... just move on and be sure to stop short from now on.
Old Dec 12, 2009 | 02:30 PM
rsxmanjoe's Avatar
rsxmanjoe
Well there would be no other way to realize the paint problem without having the bumper come into contact with something. I do agree that they're probably not going to help me out, but I'll have to go to small claims and test my luck there.
The bottom line is they didn't do their job properly. Say you buy a new vette and decide to give it a rip through the gears and in the process the clutch disk explodes into pieces. Is that the owners fault or Chevy? Chevy could argue the car shouldn't be reved to its max nor should you be shifting gears that quickly, although when you bought the car you were under the assumption that revving it to its max and shifting gears would be ok. Sort of a grey area
Old Dec 12, 2009 | 02:38 PM
dougbfresh's Avatar
dougbfresh
Bite the bullet dude-SMALL CLAIMS, are you kidding-you hit the curb. Ever see a older Ford or Mopar where the factory paint came off in SHEETS after a few years? It happens! Maybe they will cut you a small break to repair it but I would NOT expect them to do it FREE. And one of the reasons there is a engine REV limiter it to try to keep most of the monkeys from blowing thing up (at least on upshifts), beleive me, if a dealer believed you hot rodded the car and blew it up they WOULD NOT COVER THE REPAIR.
Old Dec 12, 2009 | 02:43 PM
rsxmanjoe's Avatar
rsxmanjoe
Older Ford or Mopar? did you not read I had this painted 6 months ago?
I was referring to shifting at 6500 into the next gear, not downshifting into 2nd at 120 miles per hour and hitting 12,000 rpms. A brand new vette being properly shifted at 6,000 RPMs should never have an issue with something happening - if it did then its the fault of Chevy. The bottom line is if this was painted properly I'd have some marks at worse and get it taken care of it with rubbing compound in 10 seconds, but now I have to pay 700 dollars to have the bumper REPAINTED the proper way.
Old Dec 12, 2009 | 02:51 PM
dougbfresh's Avatar
dougbfresh
Say YOU, we don't know how hard you hit what you hit (and neither will the guy who painted it). Is it Lowered too???
To Paintjob chipping
Old Dec 12, 2009 | 03:13 PM
rsxmanjoe's Avatar
rsxmanjoe
i think its slightly lower then stock - i pulled into the spot at under 5 mph....its just one of those ****ty situations where its a grey area.
Old Dec 12, 2009 | 04:33 PM
rbrtclk's Avatar
rbrtclk
You want to make sure when it's redone that the shop uses an adhesion promoter. Had the same problem after a repaint, came off in sheets.
Old Dec 12, 2009 | 07:38 PM
SaberD's Avatar
SaberD
prepped incorrectly for sure. they should have to fix it imo.
