Factory wheel sensors! help
Old Mar 2, 2002 | 12:47 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Factory wheel sensors! help
If I get aftermarket wheels without them, can a stop an error code from showing up? Is so, how?
Also, can any aftermarket wheels be fitted with the sensor or already has them?
I was thinking aftermarket 2001 sytle polished, or used OEM Z06 wheels. These have them right?
I'm about to take the rears off for drag radials, when I put the stock ones back, any errors should clear, right?
Sorry guys, first 48 hours with a C5 :D
Old Mar 2, 2002 | 01:42 AM
97silverbullet's Avatar
97silverbullet
Default Re: Factory wheel sensors! help (TexCorvette)
I was also wondering almost the same thing. What sensors will work in ZO6 wheels on my '97? I keep getting different answers.
Old Mar 2, 2002 | 07:10 AM
TexCorvette
Default Re: Factory wheel sensors! help (97silverbullet)
Hope we get some right answers soon. I need larger wheels!
Old Mar 2, 2002 | 12:30 PM
RickSilverC5's Avatar
RickSilverC5
The wheel sensors can be taken off the stock wheels and placed on the new wheels. No problem. Just check with the wheel maker to see if the sensors will fit the wheel. Most will. :cheers:
Old Mar 2, 2002 | 01:24 PM
wottogo's Avatar
wottogo
In the wheel/tire section there is a post that states the error message will show up about 200 times and then stop. 'Reset' each time you start up will drop the error message. I have GM #10438853 sensors from 'Ken Fichtner" on OEM Z06 wheels. That # is the stem mount type and I believe works on '97-'00. I haven't put the stock wheels and EMTs back on yet and do not know if I will have to relearn them or not. (Relearning is in the tech tips section). Be good to yourself.
Old Mar 2, 2002 | 01:36 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Factory wheel sensors! help (wottogo)
How much are new wheel sensors?
To Factory wheel sensors! help
