Do I need a larger MAF?
70,789mi. currently on stock short Block.
PRC stage 2.5 5.3 heads
TSP 233-239, .595/.604, 112ls
FAST 92mm Intake
92mm Throttle body
VaraRam B2 System
Summit 25% UD pulley
LG Streets 1 3/4 long tubes
3" Off Road X pipe
Corsa Pace car exhaust with tiger shark tips
Centerforce Dual Friction Clutch
RAM billet steel flywheel
I had a highway tune done and was left with idle surge, The exhaust fumes are so strong they make my eyes water and my clothes stink. I plan on getting another tune this spring but I am wondering if....Here is where you guys come in.. Should I spend my money and get the TSP 100mm MAF? Before the tune.
Are you running cats? If not, your exhaust is going to stink not matter how it's tuned.
FAST 92mm Intake
92mm Throttle body
VaraRam B2 System
3" Off Road X pipe
The fumes are most likely caused by two things. No cats and cam overlap. The more overlap your cam has, the more fumey it is going to smell at idle as raw fuel is sucked out the exhuast.
The only reason, I think, you should upgrade to a 100mm MAF is if you've eliminated all restrictions before the MAF by running a 4" diameter intake tube of some sort. Otherwise, the stock MAF is capable of support 600.
You have a pretty aggressive mod combo. I'd save the coin on the MAF and put that into a tune from an experienced tuner. Idle surge is usually caused by improper values in the idle tables including spark. This causes transition problems as the computer seeks to maintain stoich while moving from the running state to idle state. So, I'd suggest getting a good tune from a good tuner.
I also agree with WKMCD that if you have a 75mm MAF you would be better off going with an 85mm MAF (unscreened). You will have to recal the MAF table for it to work well, but that can be done during the tune. I don't think you will see any increase in HP, because even though an MAF is an orifice an MAF is just a meter. An MAF uses a thermal transfer function to measure the mass of air moving through it. So a 75mm MAF will measure, say 150 g/s the same as an 85mm MAF will. The only difference being the velocity of the air will be greater with the 75mm MAF. However, at WOT and high HP levels a smaller MAF can contribute to less than atmospheric pressure due to the amount of air that can fit through the smaller opening. This can cause slight levels of vacuum when monitoring the MAP sensor. This will result in slightly less WOT power. An 85mm MAF will reduce this. I'm not sure how much peak power you'd lose between the 2 but the 85mm MAF will give you slightly better 'throttle response', and that is always a good thing. Also, the 100mm MAF's use a different sensor and that can cause problems in calibration. I'd bet you'd run out of cells at the top of your table with a 100mm MAF. I did. See my sig. Sheesh, what a mouthful, sorry.
I am running the stock MAF behind the VaraRam Maybe just the SLP or even the MTI housing would help.
I know that the exhaust will stink but my car is running so rich that it is turning my tail pipes black. I understand that I will not be able to eliminate the smell alltogether.
The surge is only about 40% of the time when I slow down it will drop as low as 400rpm then jump to 1300 then down to 600 up to 1100 and so on...
This Spring JJFormato is going to be in Gettysburg PA early spring. I hear he is the best and he said he could eliminate all the problems I have. I am just wondering if a larger MAF and a set of 42lb injectors would assist in the tune seeing as though they are about all that is left thats still stock.
When I had the H/C/I done I wanted everything tuned, it was 500 bucks for a dyno tune or 250 for a highway tune where they tune it basically by ear and handling issues. Guess I wasted my money huh?
On the MAF, depending on how much of the intake you are willing to change, you might want to consider the MTI racing composite 78 mm MAF (not sure its still available) the only internals are the wires so without the airfoil stuff the cross sectional area is about the same as a stock 85 W/O the screen. You will have to have the MAF table adjusted but this allows you to keep your existing intake plumbing.
Just my thoughts - hope this helps a bit - good luck.
I did add a 100mm PowrMaf but I also did this intake at the same time.
either you are or you arent,
it would show in your A/F ratio in teh high RPMs and it would show in your tuners logs of pulsewidth and duty cycle on the injectors.
there is no "maybe" about it,
find a new tuner.
There is no read out.
No logs.
I am in search of a new tuner but asking my fellow members if they would suggest I get a larger MAF/Injectors/Rails prior to tuning again. This will rid the tuner of all possible problems as far as maxing the F/A ratio out goes. You following me? He would be able to tune the car to its fullest potential.
I want to avoid going to a tuner and at the end he tells me if such and such were larger he could have run it up to XXX... The last tuner shut me off at 6000 rpm. My car is still blistering the road at this point and I am forced to shift. I agree the more I read the more I get steamed about wasting that 250.00.
What I'd suggest you do for now, based on your questions and where your car is at right now is this:
1) Find a good tuner that will add the below 2 components to your system BEFORE the tune:
2) get a known good working OEM 85mm descreened MAF (Delphi) this would be a 2001+ with screen and pull that out, or a Z06 MAF.
3) get a 3pin to 5pin adapter for the MAF since you have a 2000 with seperate intake temp sensor. (it's integrated into the newer MAF's)
4) Get a set of 30lb SVO or equivalent injectors.
When I say equivalent, I mean pintle-style, not disk-style, and 30lb/hr @43psi, NOT 58psi. Most injectors are rated at the 43psi.
Go here for more info: Injector Info
5) Don't install either until you get to the tuner.
Have them install those pieces before the tune. It should take about 1/2 hr for both.
6) They can then read your PCM and then put default values for the associated tables into your PCM and begin the tune.
If you purchase those components and install them into your car without changing the PCM table values for them the car will be VERY out of tune and you could be running so rich there will be a chance of doing damage, (washout, fouled plugs, etc.)... MAYBE, but why take the chance.
Then I saw one of Jeremy's threads about Gettysburg and the rest is history. Great tuner.....
...He will be working his magic on my new Z this spring.....
When my cats were gutted, I had the smell and the exhaust film covering everything back there....another reason why I couldn't sneak up on anyone.
Get to a reputable tuner and let him log some data while putting your car through the paces and if you're lucky, you'll only shell out the cash just once. I paid 1k total between 2 tuners but my issues were solved Give Jeremy a call and if not, theres alot of fine establishments here in the NY, NJ, PA, MD area that could help you out.
Let me know how you make out.
Good luck.....
