Is an alignment needed????
Old Dec 13, 2009 | 05:28 PM
8VETTE7's Avatar
8VETTE7
Default Is an alignment needed????
Old Dec 13, 2009 | 05:37 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
You could probably get away without an alignment but at $100.00 and considering the price of tires, I'd do it.
Old Dec 13, 2009 | 06:51 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I All it takes to take the cradle loose is taking the the upper A arms loose. If you had any shims and put them back in their respective places, then there is no need for an alignment.
Old Dec 13, 2009 | 08:04 PM
Its_Go_Time's Avatar
Its_Go_Time
Simply removing the rack won't change the toe setting of the wheels, assuming the tie-rod adjusters weren't messed with. The worst you could expect is the steering wheel to be off centre a little, but I doubt you'd even see that.
Old Dec 13, 2009 | 08:21 PM
lionelhutz's Avatar
lionelhutz
If the rack was the only suspension part removed and the A-arms and such were left alone then there's no need.
If it's been a while then you could do it anyways...
Peter
Old Dec 13, 2009 | 08:33 PM
jrose7004's Avatar
jrose7004
I would get one.
To Is an alignment needed????
