Go with 3.42 vs 315 rear end on a 900RWHP, pls advise!!
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi all!!
I have the 427 cid twin turbo 900RWHP C5.
I has around 1050RWTQ and it's spinning all the gears!!
Because the big torque issue, I'm thinking to swap the 3.42 rear end to thhe 3.15 for less spining and better displacement!!
What advantages/disadvantages performance will confront?
Any suggestion and advise?
Comments pls!!
Comments pls!!
Hi all!!
Because the bit torque issue, I'm thinking to swap the 3.42 rear end to thhe 3.15 for less spining and better displacement!!
Comments pls!!
Comments pls!!
![](/forums/images/ranks/2k-3k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Ive been in Brets 02 Z and it runs 911 rwhp and he had his stock rear wheels widened to a 12" setup and tubbed it...granted theres some wheelspin but for the most part it hooks up HARD.
Go the widening, tubbing and better tire route before spending all that money on a new built rear.
![](/forums/images/ranks/5k-6k.gif)
wont help much.....once its in the RPM's, its gonna spin regaurdless. Your best bet is to do what is stated above. You need better wider tires. Id do a MT 345 drag radial on a 12 inch wheel.
I know that exist the drag radials, ect but just thinking to put a taller rear end and can take more advantage to the boost and power curve.
What do you think?
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
then that will work well. you will stay in the meat n taters of the boost longer. and 4th gear will be going to like 175 mph(ish)...that is if you have a MN6
I just recently had a BAD situation with the 305 MT's, but those were a new mold and their process failed. I separated the sidewalls, but I know the 345's have ben around for a while and many high speed people run them. With your power, I know you can do prob 210+...which Im sure they are NOT good for. Im sure you use your power way more from 70-170 than high speed crazy runs...
you can check the speed rating...Ive had the BFG's and Nittos to 180+ many many many times...
what about 3.15 rear end and MT drag radials??
![](/forums/images/ranks/4k-5k.gif)
There's your problem right there. there is no way those tires will hold the power you're making. They barely held my cars power when I had 400rwhp. I'd definitely go with some 345/35/18 M/T's. I run the 315/30/18 M/T's with 760rwhp and they hook pretty good and are stable at 140mph+ from what I've experienced. I get 1.5 60' at the track no problem with these tires as well. I'm not saying these will solve your traction issues completely, but they will definitely be a HUGE improvement over the Pzero's.
How can you just realize you have traction problems with that much torque. Did you wake up one day and accidently put in a twin turbo 427? Maybe that will happen to me.
![](/forums/images/ranks/7k-10k.gif)
The Mickeys hook good
I still think with that much TQ they will still spin at slower speeds but it should get you hooked up once you get up in the MPH. Lovin' those vids BTW if you have any more pm them to me
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
You could always opt for a taller tire. It would be essentially the same thing as a gear change, but you'd also get the added benefit of more sidewall.
![](/forums/images/ranks/3k-4k.gif)
I don't know too much about vette rear end strengths, however, do you have hardened half shafts? Can you put the hardened half shafts in a 315? Like I said, maybe stupid questions but I thought perhaps I'd just throw it out there
![Agree with stupid](https://www.corvetteforum.com/forums/images/smilies/iamwithstupid.gif)
I had a hardened shaft....I twisted it after just 3 launches. there are some companies out there making crappy ones. Go to RPM and they will explain what to run. I run the new shaft (hardened) and have launched over 20 times now with no issue. Also, I think every vette needs a DTE brace
You could proabably drop down to 2.73 gears like "Smoove" (aka Jamie) did on his TT turbo vette.
He was happy with the results. Also try some sticky tures like RA1's or R888's by Toyo.
