Patch/Plug Y-Rated Tire OK?
Old Mar 2, 2002 | 02:55 PM
MelloYellow's Avatar
MelloYellow
Default Patch/Plug Y-Rated Tire OK?
I have a slight leak on my new Driver Front tire.
Going to get it checked out in a bit.
If I have it patched, will it lose it's Y-Rating?
Should I replace it??
Old Mar 2, 2002 | 03:07 PM
gmblack3's Avatar
gmblack3
Default Re: Patch/Plug Y-Rated Tire OK? (MelloYellow)
I had the left rear patched on my Z06. Its fine.
Old Mar 2, 2002 | 03:42 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Do not under any circumstances ever "plug" a tire... Only patch from the inside and you do not loose the rating on the tire...
Nick
Old Mar 2, 2002 | 05:58 PM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: Patch/Plug Y-Rated Tire OK? (Smoke-N-Shot)
Hi all,
I recently had a screw removed/tire patched from one of my Firehawks by Firestone and the service manager advised me that it was no longer "Y" speed rated for the original rating. He said that it was officially now rated at around 120MPH, if I can remember correctly. He also said that I "could" go faster than that, but that he legally had to tell me this to release them from liability reasons by law!
Steve
Old Mar 2, 2002 | 06:58 PM
MelloYellow
Default Re: Patch/Plug Y-Rated Tire OK? (Blackjetvette97)
Hi all,
I recently had a screw removed/tire patched from one of my Firehawks by Firestone and the service manager advised me that it was no longer "Y" speed rated for the original rating. He said that it was officially now rated at around 120MPH, if I can remember correctly. He also said that I "could" go faster than that, but that he legally had to tell me this to release them from liability reasons by law! Steve
Thx Guys. Will patch it.
Does losing the speed rating only apply to Runflats?
Steve, were your Firestones runflats?
Old Mar 2, 2002 | 09:00 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My recollection is that Goodyear allows the tire to be patched from the inside one time without losing the speed rating, Firestone does not. Or maybe I have that backwards. In any event, the tires are not that much different. I think that the lawyers have more to do with this than the engineers.
Old Mar 2, 2002 | 09:24 PM
Blackjetvette97
Hi MelloYellow,
Yes, mine are EMT's with a "Y" rating. I guess when a tire is penetrated by a screw or whatever, it permanently weakens the structural integrity of the tire, thus lowering the speed rating. Makes sense.
Steve
Old Mar 3, 2002 | 12:45 AM
MelloYellow
Thx Guys. I guess with a minor leak even if the patch goes it would only allow a minor leak. Maybe I can keep this tire.
It might be the valve stem. How hard is it to replace one of our valve stems??
Old Mar 3, 2002 | 04:40 AM
wottogo's Avatar
wottogo
I just had a slow leak at the tire stem/sensor unit. It seals with an o'ring on the inside. I took a 3/8 drive deep socket and tightened the mounting nut with a short grip on the ratchet. No more leak. Worth a try if you just had tires put on, as they take the sensors off to mount tires, and may not have had a deep socket. Check all of them at this point.
Old Mar 3, 2002 | 12:50 PM
MelloYellow
Default Re: Patch/Plug Y-Rated Tire OK? (wottogo)
[Modified by MelloYellow, 5:25 PM 3/3/2002]
Old Mar 3, 2002 | 06:25 PM
MelloYellow
Went out & bought a 3/8" swivel ratchet and an 11mm Deep Socket.
Well.. The tire that's leaking, the stem just keeps turning and turning like it's stripped. If I wiggle the stem I can hear air leak out.
The other stems are all tight. The bad one I must've spun around more than 10 times. It's screwed. So, probably a bad stem, which means the tire is good. Either that or I broke it myself. LOL!! I did use a bit of TQ on that first one. But, looks like it was bad.
Thx!
Old Mar 3, 2002 | 07:23 PM
nmbis2k's Avatar
nmbis2k
My picked up a screw in the left rear. Patched very carefully, and balanced back like it was.
Now seems to slowly leak a little more than the other three when parked for days at a time. I am not worried unless I could sustain >140 mph, which opportunity does not exist. Maybe for 10 seconds per blast.
And remember, a piece of chewing gum stuck to the tread at 140 mph, is going from zero, to 280 mph, and back to zero....real fast.
Old Mar 3, 2002 | 09:06 PM
MelloYellow
Default Re: Patch/Plug Y-Rated Tire OK? (nmbis2k)
Thx.
What's that about the 280mph chewing gum? :confused: :D
Ooops. Looks like I either broke the valvestem or accelerated the failure. My front tire is 100% flat now. :( Welp.. guess I get to test out my air pump. Hopefully the problem was the valvestem and I didn't create a 2nd problem. LOL.
Old Mar 5, 2002 | 08:12 PM
MelloYellow
FWIW, ended up being that the bead on the tire wasn't sealing 100%.
Luckily the tire is fine.
Old Mar 5, 2002 | 08:36 PM
rbeckham's Avatar
rbeckham
This is actually a serious issue if you drive to the track. While I have not yet had a puncture of a race tire (I use Kumhos) I have had several on my street tires (both Corvette and "other" car).
My feeling is that I would never want to drive on the track at 140+ with a patched/plugged tire, but I wonder if I am being too conservative about this. Does anyone know for certain whether the repair technique (and original puncture) damages the tire enough to worry about it? I am speaking of the "internal patch & plug" technique).
Old Mar 5, 2002 | 08:50 PM
MelloYellow
Default Re: Patch/Plug Y-Rated Tire OK? (rbeckham)
Was planning to replace the tire if I had to patch it.
Glad I didn't have to.
Someone above said a patched ZR/Y was only rated for 120mph.
Old Mar 5, 2002 | 09:39 PM
rbeckham's Avatar
rbeckham
Thanks and yes, I understand this is what the Firestone Service Manager supposedly said, but I do not consider this necessarily good information. I just have to consider the potential of having to discard an otherwise good racing tire in such a situation.
I raise this question because I have gotten conflicting advice from people I otherwise would trust about such a thing. Some say that the initial trauma to the tire, plus reaming the hole and patching/plugging it cuts enough cords to destroy the integrity of the tire so that one would not want to drive it at high speeds. Others have told me that such a small thing as a puncture and associated repair will not effectively affect the high speed capabilities of the tire (again, 140+ mph plus hard cornering). While I would not much worry about such a repaired tire in a low-speed event (e.g. autox) I also need to worry abut high speed events. Does anyone know what the real story is on tire puncture repairs and the integrity of the tire in such a situation?
Old Mar 5, 2002 | 09:45 PM
MelloYellow
Agree. Just second hand opinions of how strong a patch is.
Not sure who the best expert would be.
Anyone have time to call some major tire manufacturer techs?
Old Mar 9, 2002 | 10:47 AM
Gearhead Jim
St. Jude Donor '13
rbeckham-
I have a similar problem with my KD SSS tires. In my case there is no air leak, but a piece of glass and a bolt (both rear tires!) went in till the cord, and maybe actually into the cord a little. I think I'm going to get a spare set of wheels and put the slightly damaged tires on them for street use, save a perfect set for the track.
BTW, I'd worry about the adhesive around the mushroom patch breaking down under the heat of track use.
To Patch/Plug Y-Rated Tire OK?
