Im going to be replacing all of my brake pads and my front rotors. Im getting the powerslot cryo-treated slotted rotors for the front and hawk hps pads all around. Right now all of my pads are standard oem pads. I'm wondering if it would be a bad idea to put the hawk pads on my used rear oem rotors that are now using a different pad. I'm going to stick with solid rotors for the rear even if i do change them. ive read that a rotor should always use the same type of pad throughout its life. So my question is should i get new rotors for the rear or not? What kind of negative effects would be involved with keeping the old rotors which used different pads previously? I'm thinking they might not bed in correctly. thanks for your help.
The only concern would be pad transfer to the rotor (i.e bedding), and this really only a real issue when going from one type of pad to a very different type of pad. If you burnish the old rotor (sandpaper), using new pads on old rotors is no issue at all...
I replaced the OEM pads with new ceramic pads, using the original rotors, and have no issues what so ever.
I wouldn't have them turned (unless you have existing wapage issues), as they lose thermal mass making them more prone to warping...As far as grit, probably 150-200grit would be fine...
Dont turn them. I have had nothing but bad luck having the rotors turned. Seems like they always warp and begin to squeel. Just scuff up and install the new pads.
I've done many, many brake jobs and I have used the same rotors numerous times. I have never turned or sanded any rotors, and never had a problem. As long as the current brakes aren't pulsating right now you will be fine with just pads.
Originally Posted by ipuig
Rotors do not warp from resurfacing on a brake lathe.
BUT THEY LOOSE PRECIOUS METAL THEN CAN CAN LEAD TO OVERHEATING THEM AND THEN THEY WARP
Incorrect, as long as the brake rotors when resurfaced remain above the minimum allowable thickness called out in the service manual, there is no more propensity for overheating related problems than if they were not re-surfaced.
Brake rotor heating under high braking loads is one of the factors taken into consideration when calculating the minimum allowable thickness stated in the service manual.
A lesser mass will result in a higher temperature. The brake system turns kinetic energy into heat. The same amount of heat applied to a lesser mass results in a higher average temperature for that mass.
Sure, they can design the system to withstand that heat within the design specifications, however, the hotter it is, the more opportunities for non-uniform cooling, which can locally distort the rotor surface, resulting in "warpage".
