replacing header gasket
Old Dec 16, 2009 | 08:32 PM
Chrohm's Avatar
Chrohm
Default replacing header gasket
what parts should I take out or disconnect to get to the header bolts?
the driver side is a bitch...
Old Dec 20, 2009 | 12:15 AM
waddisme's Avatar
waddisme
I have my A.I.R. system removed so it makes it much easier on both sides. On the passenger side, you will have to remove oil dipstick bracket. It also helps to remove some of the spark plug wires. Good luck with it.
Old Dec 20, 2009 | 11:35 PM
Tech's Avatar
Tech
I always remove the alternator, AIR valves, coil packs w/ bracket and dipstick tube. If you get all of that stuff out of the way, you're knuckles and fingers will thank you.
Old Dec 21, 2009 | 12:10 AM
ILM-Express's Avatar
ILM-Express
MFIC
To replacing header gasket
