Michelin Pilot Sports
Old Mar 2, 2002 | 04:47 PM
Sniper168gr's Avatar
Sniper168gr
Default Michelin Pilot Sports
Took a car for a ride today with the new wheels and tires. The ride seems a little harder I would guess to the lower profile and wider tire. However, the steering is much lighter and the car handles way better than it did before. :cheers:
BuckMaster - Any news on your wheels yet? :chevy
Old Mar 2, 2002 | 05:00 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Michelin Pilot Sports (Sniper168gr)
what tire pressure are you running? The ride should not be harder unless the tires are over inflated. :eek: And we all know what that means!! :cry
vetterdstr :cheers:
[Modified by vetterdstr, 2:41 PM 3/2/2002]
Old Mar 2, 2002 | 05:51 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Michelin Pilot Sports (vetterdstr)
Are thoses the Mallet 396 wheels? What size tires are you using?
Old Mar 2, 2002 | 09:02 PM
Sniper168gr
vetterdstr :cheers:
They are inflated to 35 pounds. Too much? :confused:
Old Mar 2, 2002 | 09:08 PM
Sniper168gr
Default Re: Michelin Pilot Sports (9D9LS1)
Hmmm... these were/are the style used by Mallet, but they are now supplied by Nate from Xtreme (supporting vendor) so they are XMS wheels. The rims and tires are as follows:
Front: 18x9.5 with a 265/35 ZR18 tire
Rear: 18x11.5 with a 295/35 ZR18 tire
... and no they don't hit anywhere. :cheers:
Old Mar 2, 2002 | 10:40 PM
lostsoulny's Avatar
lostsoulny
I say 35 is too much ... I keep my runflats at 30-31 cold, I have read non runflats should be at 32 cold... so if your 35 is a cold reading it is a bit high and definately would affect your ride.
Old Mar 2, 2002 | 11:06 PM
Viprklr's Avatar
Viprklr
Default Re: Michelin Pilot Sports (lostsoulny)
I agree. 30psi cold is the way to go. With a little driving they'll creep up t0 32psi. That should help with the ride. :cheers:
vetterdstr's Avatar
vetterdstr
35 should not be too much... I was thinking that you may have had it way over that. You can try 32 to 34 and see if the ride is better for you. Be sure to keep an eye on how your tires wear, just so you have the proper inflation for your car.
vetterdstr :cheers:
Old Mar 2, 2002 | 11:13 PM
Sniper168gr
Thanks everyone! I'll lower the pressure a bit and see if there's an improvement. :yesnod:
Old Mar 3, 2002 | 12:04 AM
jschindler's Avatar
jschindler
I agree with the 30 cold. Don't forget too that with your 18's in front you have given up 1/2 inch of sidewall. I have the michelins also in 17's up front and they definitely ride better than the stock run-flats.
Old Mar 3, 2002 | 12:08 AM
Redline Motorsports
Default Re: Michelin Pilot Sports (jschindler)
The Mallet 396 are the same ones that Nate sells. Nice wheel. I have a set coming in a couple of weeks!!
Wish I could find a 315 35/18 for the rear...
Old Mar 3, 2002 | 12:09 AM
jschindler's Avatar
jschindler
You and me both. I'd trade my practically new Michelins immediately if a good tire comes out in that size.
Old Mar 3, 2002 | 09:47 AM
YO-EL's Avatar
YO-EL
I run mine at 30F/31R cold...
This is the Mallett spec for the Pilots...
To Michelin Pilot Sports
