Questions about "Off-Road" X-Pipe.......
Old Mar 2, 2002 | 06:43 PM
97C5ENVY's Avatar
97C5ENVY
Default Questions about "Off-Road" X-Pipe.......
1) Does anyone make any full length off-road X-pipe (from LT headers(TPIS) to the over-axle pipe)?
2) If so, are the made with a "slip-fit" connection on the TPIS header side and flange connectors on the over-axle pipe side?
Old Mar 3, 2002 | 12:05 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: Questions about "Off-Road" X-Pipe....... (97C5ENVY)
Old Mar 4, 2002 | 12:30 PM
97C5ENVY's Avatar
97C5ENVY
Surely SOMEONE out there has looked into this before and knows if there ARE any vendors that make or sell such a item. ANYONE?????
Old Mar 4, 2002 | 01:20 PM
Stunt's Avatar
Stunt
I believe most of the tuners make custom, full lenght off-road X-Pipes. I say custom because they differ on how the connection is made on the header end. (like you say, TPIS is slip fit, others have flanges and they are not necessarily the same).
I'm running TTS headers and have a flange connector on both ends of my X-pipe (yes it does run the full lenght from the header collector to the over-the-axle pipes/mufflers).
Hope that helps a little.
Old Mar 4, 2002 | 03:06 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: Questions about "Off-Road" X-Pipe....... (Stunt)
Whew! Finally someone answered. :crazy: I kinda figured it would have to be a custom job........but i was hoping for the easy way out. :D
Just curious, what's an approximate cost for a custom job like this? Thanks!
Old Mar 4, 2002 | 05:38 PM
Stunt's Avatar
Stunt
I believe the cost was around $350.
Old Mar 4, 2002 | 07:14 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
So this custom, full-length off-road x-pipe would replace both the cats and H-pipe?
-Tuan
Old Mar 4, 2002 | 09:10 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: Questions about "Off-Road" X-Pipe....... (Tuan Le)
-Tuan
That's what i'm looking at doing. I was hoping at least one vendor made them....but doesn't look like it.:(
Old Mar 4, 2002 | 09:16 PM
97C5ENVY's Avatar
97C5ENVY
I kinda figured it'd cost about $400. Thanks for your help! :cheers:
Old Mar 4, 2002 | 09:20 PM
LT1GMC's Avatar
LT1GMC
Check out the group purchase area, I believe Bassani makes just what you are looking for, as well as some other companies. You have to look good though, as they do not advertise this much.
To Questions about "Off-Road" X-Pipe.......
