Cam on stock A4 ?
My car needs to be able to idle close to normal, I just want to replace the camshaft while I'm replacing all these parts and want a little boost of power from the whole deal.
I have LS6 intake
Blackwing CAI with Power Duct
BBK 80mm TB
1.8 Crane Gold Rockers
B&B headers
Corsa Catback
160 thermostat
A good cam choice that i would pick for reliability and smooth idle as you want would be something below .230 @ 50 duration--lift is not that important but keep it under .600 with your 1.8's--Keep the LSA no less than a 114 for a smooth idle---With this cam choice you would need a mild stall converter--between 2400-3000 to take advantage of the raised HP curve- As far as overheating the trans fluid and reliability is concerned -with a stall--there are many horror stories out there for a street car--the key is to keep the converter diameter stock--The largest stall you can go on a stock diameter converter is around 3000.
When going to smalller diam. converters the lock-up assembly is so small it is usually the thing that makes them break or overheat
As an example i recently tuned a silverdo trk with a Z06 cam for a weekend warrior--ET's before were 14.80 after the Z06 cam install he went slower---15.00 !!! then they installed a 3000 stall--and ET's went to 14.10----
change TC. I have no budget left for it. I'm already replacing the chain, oil pump, water pump, lifters, so my budget for this upgrade is over my limits. I just want a mild, but better than stock replacement for my tired stock 1999 LS1 cam. yes an small upgrade on power will be good, I'm not looking for any major power boost out of the cam.So far I'm in between Comp
XR259HR
206/216 .515/.522 112 LSA
XR265HR
212/218 .522/.529 114 LSA
XR259HR
XR265HR
are you going to install the cam yourself? cause i wouldnt pay to install a small cam like those listed..just not worth it IMO
I'm just looking for an easy 400RWHP that I can drive everyday with the stock converter
, but then i had refused to change stall,NOW im going to change the stall for that ever increasing desire for more speed,,then ill probably change cams again since ill have the stall
,so when does it ever end?
HP ?
What say you tblu92?
I'm hoping the hp/tq are some where near the 400 range.
I have to step on the brake A LITTLE harder than I used to, but it's not bad at all, very drivable. No stall. 409RWHP.
The 212/218 will kill the 224/228 in the midrange, but loses out above 5400 RPM. Just depends on what you want. And the smaller cams are real easy on the valve train. You will feel only a very faint lope with a 212 or 216, and they idle perfectly and pull harder than stock from 800 RPM. Expect about 30 tq and 25 HP from one of these, even without headers.
Just last week we installed a baby 216/220/.530 Comp in an '04, with tuning, LG headers and a Blackwing as the only mods, and got 381 RWHP and 375 RWTQ. But the big reward: torque was above 350 RWTQ by 3000 RPM.
What a fun tire burner for running around town.
So, take stock on what you want and pick the cam accordingly. If you want max HP and don't mind sacrificing some amount of reliability, smoothness and midrange fun, then get the 220+ cam. If you drive on the street and love to light 'um up, go with the 212-216 ish cams.
Of course, opinions are like cams, everybody has one.
One thing we all agree on - just do it!
Cheers,
DG
Cheers,
DG
XR265HR
will be the one I buy, because with my 1.8 Cranes will lift just a bit more and that is about all I will need. I do ocassionally hit the track, but street driving is 95% of my driving. Also this set-up should be good on my stock converter. I might order it tommorow, I have to do price shopping first.
Thanks for all the advice
http://www.compcams.com/Community/Ar...ID=-1044516358
I reviewed the 3-cam article mentioned above, and selected the 265HR cam based on that wonderful torque. I'm an old fart, and this cam idles and drives like stock, with just a hint of lope thru the Ti mufflers.
Mine makes 360 RWHP/355 RWTQ without headers. The only other mods are a BW intake, Ti mufflers, and a UD pulley.
Yeah, I know I need headers, but they are so crude, hot, scrapey, rattley; yada, yada.
Yes, the lift will be .560 with your rockers, so probably the Comp 918 springs would be advised - not the smaller 915 that I have.
I recommended the 216/220 because in my nephew's '04 it seems to idle and drive as well as my 212, and would have a bit more oomph to complement your heads. Certainly no issues with a stall in your A4 - the 216 pulls strong from 800 RPM, very much like the 212.
DG
DG
thanks for all that good info, but I'm pretty set on the cam, I'm getting to be an old fart soon so it will work for me too.
I got brand new PSI Maxlife LS1511 springs on the CNC heads right now
http://www.usaperform.com/valve-spri...acturers_id=16
So no problems here.
After seing your numbers it should be pretty easy to have the 400RWHP that I was looking for with my set-up.
I like to work slow and take my time with my work so I see this project ending sometime mid jan.
Will keep everyone posted.
