window won't go down
Old Dec 19, 2009 | 11:36 PM
corvettegt's Avatar
corvettegt
Default window won't go down
passenger window won't go down and my door unlock doesn't for the passenger door but works for the driver side
Old Dec 20, 2009 | 05:27 PM
97C5owner's Avatar
97C5owner
Mike Mercury wrote a "how to" post on this problem. The culprit may be inside the loom between the fender and the door. This is usually where the wires become pinched. Common C5 problem.
Can you hear the relay tripping when you try to roll down the window?
Old Dec 20, 2009 | 08:56 PM
CordMcNally's Avatar
CordMcNally
Wiggle the accordion like rubber thing between the door and fender while you're trying to roll your window down. I'll bet you that your window starts working. If so, there are plenty of write-ups to help you out.
To window won't go down
