No reserve fuel
Old Mar 2, 2002 | 11:26 PM
zoneblock's Avatar
zoneblock
Default No reserve fuel
This is a bit strange, but I don't get a reserve fuel, or low fuel on my DIC. All I get is a "check GAGS (gauges)". Seems like the fuel gauge is acting funny too. It goes past half a tank and then within say 50 miles I get the "check GAGS". I fill it up and there is about 5 gals left in the tank. Anyone experience this? I hate to think that I have to take it into the dealer for them to violate my baby. :sad:
Old Mar 2, 2002 | 11:57 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: No reserve fuel (zoneblock)
I think you will have to take it in to the dealer, bud...that is really wierd--
Good luck-- :cheers:
Old Mar 3, 2002 | 12:02 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Gotta go to the dealer on this one............Sorry :cry :boxing
Old Mar 3, 2002 | 12:09 AM
intel55's Avatar
intel55
never heard that one b4... the dealer may need to "operate" :eek:
Old Mar 3, 2002 | 12:51 AM
01C5fan's Avatar
01C5fan
This is just another flavor of the fuel sending unit problem. Mine started acting up in the first 2k miles. After reading several posts from guys who had their fuel senders replaced and still had the problem, I decided to live with it. Have about 14k on the clock now and while it still happens from time to time, it's much less frequent. Go figure. You'd think GM would have solved this by now, but apparently they haven't. Good luck.
Old Mar 3, 2002 | 03:28 AM
Saving41's Avatar
Saving41
Default Re: No reserve fuel (01C5fan)
I have just returned from the dealership for the very same problem. It was explained to me that the oxigenated gas in California (MTBE) is eating away the electrical contacts on the circuit board in the fuel sending unit. This causes the gas guage to react the way it does. I was informed that Chevrolet knows about the problem, but does not have a solution as of yet. The Dealer I am working with wants to replace the circuit board with a new one ( same design as the one that is failing) and then replace that one when an upgraded one is available. They hedge their bets by saying that the fix may only last a day, but if I am lucky, maybe longer. I would be very surprised if Chevrolet would redesign anything until they see what kind of crap gas California will end up with after the mandated reformulation. Also, I can still see their success with the colum lock situation. Makes you wonder how much the CARB Board members were paid off during the initial MTBE evaluation process. :mad
Old Mar 4, 2002 | 09:45 PM
zoneblock's Avatar
zoneblock
Default Re: No reserve fuel (Saving41)
I can't help but think that is so much dealer :bs , and they just want to tell us something even if its :bs . Saving41, looks like you and I are the only ones having this problem so I bet GM isn't going to be in a hurry to fix it. arggggg :mad
Old Mar 5, 2002 | 12:19 AM
gbm's Avatar
gbm
Had the same problem. Definitely a warranty item. They fixed it last year and haven't had a problem since....
Old Mar 5, 2002 | 01:23 AM
Saving41's Avatar
Saving41
Default Re: No reserve fuel (gbm)
gbm,
What did they do to fix your car?
Old Mar 5, 2002 | 02:24 AM
zoneblock's Avatar
zoneblock
Ditto, and when last year?
Old Mar 5, 2002 | 11:13 AM
gbm's Avatar
gbm
They told me that they "replaced a sensor". I'll check later when I get home and look at the actual work-order for a p/n if you are interested.
gbm
Old Mar 5, 2002 | 11:17 AM
01C5fan's Avatar
01C5fan
Yes, please post p/n and any other details. Thanks.
Old Mar 5, 2002 | 12:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: No reserve fuel (intel55)
Last time I didnt get the "reserve fuel message" my guage read 1/4 tank but I "ran out" of gas....defective sending unit...replaced under warranty but a PITA.....so looks like a trip to the dealer...Good Luck
Old Mar 5, 2002 | 03:45 PM
zoneblock's Avatar
zoneblock
Ditto, when going to the dealer information is a good weapon against dealer :bs plus if this is an isolated situation (seeing the number that responded to this) they might not have come across it before. :seeya
Old Mar 5, 2002 | 10:08 PM
gbm's Avatar
gbm
I had it done in late October last year. They marked on the work order that they "replaced the RH (right hand) Fuel Sender.
When I had the problem, it was just like someone said....once the fuel gets to a certain point, the gauge becomes completely inaccurate. I remember that when I got to right near an 1/8 of a tank, the "reserve fuel" never came on, nor the "low fuel" and then the fricken tank would drop below emtpy. Had to bring the car in right at that point to show the clowns what was going on.
Take it in and get them to take care of it. This is a common problem obviously.
GBM
:flag
Old Mar 6, 2002 | 01:29 AM
Saving41's Avatar
Saving41
Thanks gbm,
your experience is simular to what the dealer has planned for me... replace the sending unit (and the circuit board that is supposed to cause this problem). I was told that the part is the same as the one being replaced, and therefore the problem should return in time. They just don't know when. I will give the dealer a try in a couple of weeks. :(
Old Mar 6, 2002 | 09:23 AM
01C5fan's Avatar
01C5fan
Thanks for the reply. I guess it's time to go see my dealer.
Old Mar 6, 2002 | 09:32 AM
jschindler's Avatar
jschindler
Does this mean the circuit board is actually exposed directly to the fuel, or it's fumes? That concerns me.
Old Mar 6, 2002 | 03:50 PM
zoneblock's Avatar
zoneblock
What I don't understand is why my "check gags" light comes on in the DIC and the HUD rather then low fuel. Before you had the sender replaced did your check "gags" light come on? :confused:
To No reserve fuel
