Need help with my tire pressure sensor??? 1999 C5
Old Dec 26, 2009 | 04:28 PM
regorih's Avatar
regorih
Default Need help with my tire pressure sensor??? 1999 C5
Hey guys.
So my rear left TPS is not working properly. Some days it works fine but most of the time it wont read and ill get the "service tire system" on the DIC.
I recently put another sensor with the same results. What do you think could make the TPS sensor not transmit the signal 100% of the time? Could it be a weak battery or something blocking the signal?
Most of the time ill get the : REAR L XXX R 32
Roger
Old Dec 26, 2009 | 05:12 PM
rws.1's Avatar
rws.1
weak battery. Average life is 7 years
Old Dec 26, 2009 | 08:04 PM
Indy's Avatar
Indy
sounds like a weak battery. you could also try to reprogram that sensor again...there are instructions here somewhere if you do a search
Old Dec 26, 2009 | 11:02 PM
Retserof's Avatar
Retserof
Cruising
Reprogramming helped with the rears on my 98, but if the car sits for a week or two in cold weather it can take a mile or two before all 4 sensors register.
Old Dec 26, 2009 | 11:45 PM
jrose7004's Avatar
jrose7004
I'd say weak battery.
Old Dec 27, 2009 | 01:23 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Originally Posted by regorih
Hey guys.
Roger
I Quoted all post as I read the OP'S post he said it happened with another Sensor also so mabey not a weak sensor but a weak reader I dont know
To Need help with my tire pressure sensor??? 1999 C5
