MAF air screen on 2002
Old Mar 3, 2002 | 07:15 PM
tgeers's Avatar
tgeers
Default MAF air screen on 2002
Hi All,
In the past I read threads about removing the MAF screen, but most had to do with older C5s. That said, the question is: "is there a benefit in removing the screen on the 2002, and if I do, should I expect any problems to arise?"
Thanks for your help.
Old Mar 3, 2002 | 07:26 PM
nmbis2k's Avatar
nmbis2k
Default Re: MAF air screen on 2002 (tgeers)
when I pulled the MAF, I thought that cutting the screen out would increase the risk of ruining the electronics. So...I plan to buy an aftermarker with no screen, tuned to more performance.
Old Mar 3, 2002 | 07:40 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
As I understand, the 2002 already has the screen removed... at least on the Z06's... let us know if you find one on your 2002....
Old Mar 3, 2002 | 08:02 PM
RWhite's Avatar
RWhite
Default Re: MAF air screen on 2002 (nevrenuf)
My 2002 A4 had the screen. I took it out w/o damaging it and can put it back in if codes are thrown. But nothing in the last 600 miles, so it stays out.
Old Mar 3, 2002 | 08:11 PM
tgeers's Avatar
tgeers
Default Re: MAF air screen on 2002 (RWhite)
Thanks RWhite, Mine is coming out too. :jester
To MAF air screen on 2002
