Does the steering rack have to be dropped to...
Old Mar 3, 2002 | 09:21 PM
C5Noir's Avatar
C5Noir
Default Does the steering rack have to be dropped to...
swap the cam out? Thanks.
Old Mar 3, 2002 | 09:31 PM
vstella's Avatar
vstella
Default Re: Does the steering rack have to be dropped to... (C5Noir)
Yes..along with the radiator and shroud and fans and etc....:D
Old Mar 3, 2002 | 09:32 PM
C5Noir's Avatar
C5Noir
Default Re: Does the steering rack have to be dropped to... (vstella)
Cool thanks :).
Old Mar 3, 2002 | 09:43 PM
C5Noir's Avatar
C5Noir
What about the oil pump? Does it need to be removed? thanks.
Old Mar 3, 2002 | 10:13 PM
Redline Motorsports's Avatar
Redline Motorsports
The steering rack does not need to completely come out of the car. You can pull it out through the drivers side wheel well just enough to get to the crank bolt. Once it is moved you can then remove the balancer and front cover. Once the cover is removed you need to remove the oil pump. There is one 10 mm bolt that is located on the bottom left side that holds the pickup in place. I sugggest that you stuff a clean rag in the opening at the oil pan just in case you loose control of the bolt and it doesn't end up in the pan!!
Once you have reached this point you are half way there!!
Good luck.
Old Mar 4, 2002 | 01:41 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Does the steering rack have to be dropped to... (9D9LS1)
Good luck.
is the other half as much fun :)
Old Mar 4, 2002 | 02:00 AM
GraveDigger's Avatar
GraveDigger
What about the ABS system. Does it need to be removed as well?
To Does the steering rack have to be dropped to...
