Anybody use a transgo?
Old Dec 31, 2009 | 11:17 PM
futuretech's Avatar
futuretech
Default Anybody use a transgo?
I have a stock C5 with a 3.43 gears and a 3200 stall. Torque management is disabled. Any advantages to using a transgo?
I run about 30 races a year.
I would like to manually shift at lower RPMs occasionally to stay in my class. Would a transgo help?
Old Jan 1, 2010 | 11:30 AM
MikeV's Avatar
MikeV
A transco kit will not change your shifting to manual. You have to change to a manual valve body and change your tuning in the ecm I think. It will make your shifts firmer. Just be careful not to raise the hydraulic pressure to high. You can damage the trans. I hope some trans experts can chime in.
You would be better off getting tuning software and a laptop which can change your full throttle shift points to where you want them in order to stay in your ET Bracket.
Hope this helps.
Mike V
Old Jan 1, 2010 | 12:47 PM
futuretech's Avatar
futuretech
Hope this helps.
Mike V
Exactly the advice I needed. Thanks!
To Anybody use a transgo?
