I have a stupid question about what you guys do when covering your car. I received a Coverbond 5 Car Cover for my 01 z and I am getting ready to put it on and noticed there is not a hole for the fixed antenna. Do you guys cut a small hole or to you unscrew your antenna?
I don't own a Z but if it was me I would unscrew the antenna if the cover is staying on for a long time. I would be afraid that if I cut a hole, I would miss the hole when putting the cover on and break the antenna.
I have a Z w/ cover. I remove the antena & put a soft rubber vacume boot over the treaded antena mount.
Thanks guys, Antenna is off car cover is on looks great... Also I love the ramp set up you have could you tell a little about it, material and ramp sizes
Every car cover I've ever bought has included a thick cloth reinforcement patch (2-3 inches round or square, small hole in the middle) with heat-activated adhesive on one side. You first determine where the hole has to go by mounting the cover with the antenna removed and marking the spot, then cutting a small hole there and ironing on the reinforcing patch over the hole. If your cover did not come with such a patch the manufacturer/seller should be able to supply you with one.
