100K Mile Tune Up
Old Jan 2, 2010 | 05:12 PM
rrod100's Avatar
rrod100
Default 100K Mile Tune Up
Hey people,
I just hit a 100k miles in my 99 coupe and wanted to give it a tune up. I noticed it doesn't idle as good as it use to. It takes a few minutes to idle at about 700 rpms. I was going to change the oil i have kn filter so clean the air filter change out the fuel filter and replace the spark plugs and wires. I wanted to know if i was missing anything. I also wanted to know if there was a preffered spark plug and wire set that i should go with. One quick question about the oil pressure sensor it went out and i figured i should replace it, however i bought an aluminum one should i return it and find a brass one. (where can i buy a brass one)
Thanks again for any advice in advance.
Old Jan 2, 2010 | 05:15 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
One thing I'd suggest is to use the GM Irridium plugs............(ac/delco)
Old Jan 2, 2010 | 05:33 PM
87SAM's Avatar
87SAM
Maybe spray the MAF down with some cleaner.
To 100K Mile Tune Up
