ls3 or Supercharger
Old Jan 3, 2010 | 01:47 PM
VETTE_MAN's Avatar
VETTE_MAN
7th Gear
Default ls3 or Supercharger
hey guys,
Im stuck between a supercharger like esc or a&a OR a fully built ls3 416
stroker. Both making the same amount of power and with stroker being a couple grand more, What do you guys think is better?
the car will do some drag racing and be on the track too. i will also be driving it, thanks so for everything in advance
brady
Old Jan 3, 2010 | 01:59 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
SuperCharger all the way!
Makes its own Cubes and you still retain great fuel economy - and if you should ever go bigger cubes it'll bolt right-up
Seriously - SuperCharger is a great safe and easy way to make excellent HP and TQ and retain extrtemely good drivability - I would go with a Centrifugal SuperCharger!
I am making 701 RWHP on my LS1 347 CID motor - safely
Thanks,Matt
Old Jan 3, 2010 | 02:04 PM
Jnape's Avatar
Jnape
Originally Posted by VETTE_MAN
hey guys,
brady
If you do many HPDE's you may want to stay N/A. A lot of heat is generated with F/I and 20+ min sessions on a road track will be very hard on an F/I motor.
John
Old Jan 3, 2010 | 02:19 PM
VETTE_MAN's Avatar
VETTE_MAN
7th Gear
Thanks guys,
If i do go N/A ls3 does anyone know a good dry sump system for the ls3 that will fit in a 2002 c5 z06. Only because i have heard they have oil problems when going over 1.2 G's
thanks brady
Old Jan 3, 2010 | 03:16 PM
VETTE_MAN's Avatar
VETTE_MAN
7th Gear
ttt
Old Jan 3, 2010 | 05:39 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
both
Old Jan 3, 2010 | 06:49 PM
WKMCD's Avatar
WKMCD
You need to figure out what kind of person you are. Some are FI and some are NA. If gross power is your end - forged 346 and lots of boost will get you there. If you intend to spent time on a road course - go NA
I prefer the challenge and simplicity of making very good overall power NA. That being said, I am now upgrading my LS2 403 stroker to a Darton sleeved 427 - still NA. We're expecting 550+/500+ with great drivability.
Old Jan 3, 2010 | 06:52 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you are going to do HPDEs, I suggest you spend some time over in the road racing section. The stock C5Z06 is a pretty impressive car. You will learn that the last thing you do is to add power.
First thing is to learn how to drive, which means seat time. Should also make car safe and reliable. Then you can start making improvements to go faster.
More power only helps one aspect of performance and that is acceleration. Just remember you have to slow down and turn also!
Old Jan 3, 2010 | 07:23 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
hey guys,
brady
416...even Nicely built 402 will do
Old Jan 3, 2010 | 07:30 PM
zeevette's Avatar
zeevette
This is a good observation. Save a grand or so on a nice LS2 stroker, and keep the compression below 10:1, and down the road slap a centri unit, and get massive power. You know you're gonna keep modding, right?
Old Jan 3, 2010 | 11:27 PM
VETTE_MAN's Avatar
VETTE_MAN
7th Gear
thanks guys the reason i said a ls3 416 was because I can get a killer deal on a fully built racing one I am going to go to bondurant racing school but since I can get a really good deal on that ls3 I think im gonna go for it im just wondering if anyone knows and good dry sup oil system for a c5 z06? thanks for all advice guys it been very helpful
brady
Old Jan 4, 2010 | 09:59 AM
Independent1
St. Jude Donor '08
brady
^^Try posting your question over in the road racing section. They have been testing out dry sumps for LS3s for T1 vettes. Saw a couple of posts on the subject over there.
To ls3 or Supercharger
