Another blinker thread...
Old Jan 6, 2010 | 09:00 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Default Another blinker thread...
OK,
My left blinkers work fine - outside the car...
the light on the instrument cluster and on the HUD do not come on though...
Right side is normal.
I have been known to do some work on my car from time to time. It is possible that I've knocked something loose under the dash. I've looked it all over and wiggled eveything electrical under there. Still doent work...
Any thoughts?
Thanks.
Old Jan 6, 2010 | 09:47 PM
Jnape's Avatar
Jnape
the blinkers tie through the hazzard switch. Many funny things happen when that switch gets old.
Old Jan 6, 2010 | 09:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, cycle the hazard switch a few times and see if it clears up.
Old Jan 6, 2010 | 09:51 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Yeah, I've cycled the hazzard switch quite a bit, but no change.
At least the people around me know which way I'm turning, even if I dont...
Old Jan 6, 2010 | 10:16 PM
byronhunter's Avatar
byronhunter
Edit---------Lucky beat me to it!!!!!!!!!
With Signal blinking, check voltage at Circuit #14. Post if you have it there, Then we'll know which way to go.
Old Jan 6, 2010 | 10:18 PM
lucky131969's Avatar
lucky131969
I disagree with the hazard switch being the culprit, especially if the front turn signals are functioning normally. From the hazard switch flasher, 12 volts is routed through the MFS, to the IP fuse block, where it splits..supplying 12 volts to the IPC turn signal indicator, and on through the DRL relay to the front turn signal itself. So if the front turn signals are working normally, it suggests that the 12 volts flasher is working normally,and the MFS is fine.
Old Jan 6, 2010 | 10:28 PM
byronhunter
You don't miss!
Old Jan 6, 2010 | 10:34 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Thanks guys, I'll get on it tomorrow.
byronhunter
Old Jan 7, 2010 | 12:27 AM
lionelhutz's Avatar
lionelhutz
I disagree with the hazard switch being the culprit...
Yup, the hazard is just the flasher in normal operation.... nothing in it's connections would affet the dash indicator only.
The problem has got to be the left signal feed where it goes to the instrument panel.
Peter
Old Jan 7, 2010 | 12:48 AM
dgrant3830's Avatar
dgrant3830
Peter
From the two schematics it appears that feed comes through the MFS switch as already mentioned. Hmmm...
Old Jan 7, 2010 | 06:45 PM
lionelhutz's Avatar
lionelhutz
Hmmm what? I can't agree with someone else?
The hazard switch is wrongly pointed out as the cause of any signal problems so many times that the real problem needs re-enforced....
Peter
Old Jan 7, 2010 | 08:44 PM
dgrant3830's Avatar
dgrant3830
Basically, I was correcting my incorrect post after seeing the schematics that were posted. I was in no way trying to claim credit from you or anything similar. I was wrong with the hazard switch which is where many blinker issues arise but the schematics tell the tale.
Old Jan 7, 2010 | 09:09 PM
lionelhutz's Avatar
lionelhutz
OK, my bad, I thought you were meaning something with my post.
Peter
Old Jan 12, 2010 | 08:14 PM
ls1forlife's Avatar
ls1forlife
i have a similar issue, but the indicator works on the HUD, just not the dash. I replaced both bulbs to humor myself, so ill see if that works
Old Apr 9, 2010 | 01:27 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Thanks guys for this info...
I went out the next day to work and trouble shoot some more. I got called away for some reason, and never made it back. I've been really busy at work, so I have not been able to finish the project.
However, I took it for a drive the other day and it is working fine...
So, if it acts up again, I'll work through your schematics, but for now, I'll just drive it.
Old Jul 19, 2010 | 12:27 PM
Bill Hilt's Avatar
Bill Hilt
I have this exact same problem . Has anyone fixed this ? Mine was sporatic at first but now dosent work at all
Old Jul 19, 2010 | 12:53 PM
mcgilles's Avatar
mcgilles
as pointed out by byronhunter the turn signal inputs to the cluster are individual wires which get 12V when the indicator should be on. the other schematic posted earlier shows where the power for that circuit should come from. you must have a damaged wire in there or a bad/loose connection somewhere trace it back with a voltmeter and figure out where the breakdown is.
To Another blinker thread...
