Correct Tire Pressures?
Old Jan 8, 2010 | 11:35 AM
LiteraCola's Avatar
LiteraCola
Default Correct Tire Pressures?
Hey guys...I normally wouldn't post a new thread about this, but I've never had a car with such radical tire sizes. My tires are 265 35 18 front and 305 35 19 rear. What would you guys recommend for how much pressure to run in them. The previous owner mentioned 40 psi in the rear, but that just doesn't seem right to me...
Old Jan 8, 2010 | 12:06 PM
jrose7004's Avatar
jrose7004
I would run 30 psi cold.
Old Jan 8, 2010 | 12:24 PM
STL94LT1's Avatar
STL94LT1
I like 30-32psi cold.
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
32 all around cold
Old Jan 8, 2010 | 01:04 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by pewter99
32 all around cold
I have always run 32 cold. Actually got 41,000 miles out of the tires on my last C5.
Old Jan 8, 2010 | 02:21 PM
pewter99's Avatar
pewter99
I actually run 35 BUT I am in Florida and I did it on recommendation of my tire guy after my 2nd set of tires on my 07Z06 went south in 11K....3rd set lasted 15K. I am doing that on my 99 and the 02 as well. Both are showing excellent wear. Climate has a bearing on what you should be running just like AS tires are not suited for warmer climates.
Old Jan 8, 2010 | 02:31 PM
dbaker's Avatar
dbaker
I run F:33 & R:30 on my 02Z. As a general rule of thumb,I vary my psi as it relates to weight dist.
Since the dist on my 02Z is 53/47,I usually run a few more in the frt.
\db2
Carolina
LiteraCola's Avatar
LiteraCola
Okay, thanks a lot guys. I'll give it a try. I didn't think 40 was a feasible option.
Old Jan 8, 2010 | 03:49 PM
Paul 75 L82's Avatar
Paul 75 L82
I've been running 30 here in Palm Beach County, maybe I should bump it up for warmer temps.
Old Jan 8, 2010 | 04:15 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Depends on the brand and type of tire too. I personally have Michelin PS2's and have found ~28 psi cold to be ideal for even treadwear.
To Correct Tire Pressures?
