Harnes...where does it go?
Old Jan 8, 2010 | 05:38 PM
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
Default Harnes...where does it go?
Ok...took the front fascia off, and trying to put it back together and this harness:
is really beating me up. I can't find out where it goes.
Its up by the right brake duct...any help would be great. I got so frustrated that I can't think straight and would like some thought for you all.
Old Jan 8, 2010 | 05:47 PM
lucky131969's Avatar
lucky131969
wire colors in the harness?
Old Jan 8, 2010 | 05:51 PM
AU Eagle's Avatar
AU Eagle
Looks to be 4 brownish type colors, 1 light blue, 1 dark blue, 1, black and one pin is just red, no wire.
It says PA66 on the harness. I just can't find where it plugs to.
Old Jan 8, 2010 | 05:53 PM
lucky131969
I believe that is an inline connector for the lighting i.e. turn signal, marker..... There should be a connector that it mates with somewhere. Should not be too far away from SP102.
Old Jan 8, 2010 | 05:54 PM
AU Eagle's Avatar
AU Eagle
That is what I thought too...it can't go far to be plugged in. I'm not sure if it got pushed somewhere when I put the fascia back on or what. I really don't want to have to take it off, but I want to get this sucker plugged in.
Not wanting to continue the project until this is taken care of.
Thanks.
Old Jan 8, 2010 | 06:01 PM
lucky131969
Thanks.
Sure. The connector is C100. It is #25 below:
Old Jan 8, 2010 | 06:06 PM
AU Eagle's Avatar
AU Eagle
Hmm...I may have to take the front off again, because I just don't see where it goes. Thanks for the picture though.
Old Jan 8, 2010 | 07:26 PM
BOTTOMS UP's Avatar
BOTTOMS UP
it's been awhile since I did mine but I hooked up all the electrical first , then bolted it up.
Old Jan 8, 2010 | 07:30 PM
AU Eagle's Avatar
AU Eagle
Nothing is bolted back up, I more or less just put the fascia back in the place, then was starting to hook things back up and noticed this bad boy.
Old Jan 8, 2010 | 07:32 PM
BOTTOMS UP's Avatar
BOTTOMS UP
better now than later
To Harnes...where does it go?
