Twilight Sentinal and Tail Light/Running Light Problem
Old Jan 9, 2010 | 05:48 PM
ocalabob's Avatar
ocalabob
1st Gear
Default Twilight Sentinal and Tail Light/Running Light Problem
New to the forum and need help for a problem on a 2002 coupe. The other day the headlights would not go down when turned off and no dash, tail or running lights. Checked on the forum and found out about fuse six. It was blown, so I changed it. Everything worked fine for a couple days. Then was driving a couple days later with the headlights on and had no tail, running, fog or dash lights again but headlights worked OK up and down. Narrowed it down to when the twilight sentinal is off, the tail lights, running lights, side lamps and fog lights will not come on with the head lights. When I turn on the sentinal, all the lights will work until it times out, then I go back to having no lights again. Could relays 43 and 44 be going bad or is the sensor creating problems? Cleaned all the ground connections discussed in previous posts. Any suggestions?
