Hey every one. I got a little problem. My have has a leak from the back of the intake mani. It is NOT a gasket. I was feeling around and i realized that the hose next to the main one (that is connected to brake booster) does not have anything connected to it. I put my fingure on it and it does suck in air.
What connects to it? I also do have a code P0410. And some times my o2 sensor codes come on. P0141 and P0161. I also done have much air coming out of my driver side vents.
Any ideas????
Not sure what you are looking for here. You have a problem, found the source of the vacuum leak...which will affect the systems you are having trouble with. Next step is remove the intake, and find the disconnected vacuum line...and repair. Sounds like you're almost there........
What? If the OP is referring to the small vacuum line being disconnected/broken, which would in turn affect the A/C, AIR, etc....how would this be a suitable repair?
You'll have to unbolt, and then move the manifold a few inches forward to get at the vacuum fitting to make a proper repair.
haha i think you are confused my friend i am pretty sure he is talking about the small vaccum line that connects the hvac. it could be possibly disconnected or broken. do your vents change or are they stuck in one position?
same question here - do the hvac vents open/close properly? - or are they all open at the same time? (likely)-- -- it Is possible to get the small brown plastic vac hose back in that fitting without removing the manifold but it takes lots of wiggling and cursing. The line commonly drops down a couple of inches when it slips out of the fitting. Look for it coming out of the larger plastic wire loom that comes up from under the battery.
Hey thanks for the help, I found the small hose that connects to it. It was a little hard to locate but i put it back in place and now my a/c works great and no more noise. And i think it will clear my code and check light.
