Another steering column lock question..
Old Jan 11, 2010 | 09:29 PM
zapp109's Avatar
zapp109
Default Another steering column lock question..
Ive had my Z06 and never looked into if anything had ever been done to the steering column lock, well today i was spraying the car off. Turned it on seen the code.. Turned it back off, then started it again the code popped up and i push reset and drove off. Turned it back off. Column locked.. Started it again and it popped up. Pushed reset and drove off.. Drove ten miles home no issues. I thought with this code it was suppose to cut fuel and not be drivable. ????
Old Jan 11, 2010 | 09:31 PM
lucky131969's Avatar
lucky131969
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Jan 11, 2010 | 09:39 PM
zapp109's Avatar
zapp109
yea i went through it and maybe i just misread.. so if you did the recall they reprogrammed it so it cuts fuel?? Soooo its just a matter of time till this thing decideds not to unlock... ?? .. better get a harness or bypass
Old Jan 11, 2010 | 09:56 PM
corvettech75's Avatar
corvettech75
check the black wire at the connector for the column lock motor below the steering column. I see these loose in the dealer all the time. Tighten the terminal and clear the codes. (motor side of connector; female terminal) test drive to see if it resets.
Regards,
Todd Von Kutzleben
Corvette Tech @ Maxie Price Chevrolet
Old Jan 11, 2010 | 10:24 PM
zapp109's Avatar
zapp109
Alright I will try it this week thanks Todd.
Old Jan 11, 2010 | 10:34 PM
corvettech75
Good luck and let me know what happens...I might be able to talk (type) you through this repair
Old Jan 12, 2010 | 02:01 PM
TEXHAWK0's Avatar
TEXHAWK0
You never said what code you got?
Did you get Service column lock, or Pull Key and Wait 10 seconds?
To Another steering column lock question..
