SVO 30lb injector install???
Old Mar 5, 2002 | 01:12 AM
DUKE's Avatar
DUKE
Default SVO 30lb injector install???
Anyone have install instructions for SVO 30lb injectors? Thanks.
Old Mar 5, 2002 | 01:56 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: SVO 30lb injector install??? (DUKE)
see my write up in the c5 tech tips section of this forum.
Old Mar 5, 2002 | 03:14 AM
racetchr's Avatar
racetchr
Duke - where did you get the injectors? Have been looking for 30lb in Dallas, no one has them. racetchr.
Old Mar 5, 2002 | 07:22 AM
abraham's Avatar
abraham
What kind of gains does one see with the 30 lb injectors?
Old Mar 5, 2002 | 11:29 AM
DUKE's Avatar
DUKE
Default Re: SVO 30lb injector install??? (abraham)
Racechr,
Got the injectors from Speed Demon a vendor on the forum. Go the them mall. He has them cheaper than Ford Motors racing. I have the MAFT turned up to 15% rich and still can't get the Long term fuel trims down...running about 12% lean. Problem is because of heads/cam and other mods....the stock injectors are maxed out for their capacity. Need larger ones to get more fuel to engine.
Not sure what you would need them for unless you have major mods as heads/cam, but with mods come more air, so to get the A/F ratio set properly got to go with bigger injectors.
Old Mar 5, 2002 | 11:35 AM
kewlbrz's Avatar
kewlbrz
abraham, larger injectors are needed, for large increases in power. However some choose to add larger injectors to manipulate perceived engine loads with a maf translator. They are used as a tuning aid in that respect. I have more info on my site.
Old Mar 5, 2002 | 11:46 AM
DUKE's Avatar
DUKE
Default Re: SVO 30lb injector install??? (kewlbrz)
I humbly acquiesce to Kewlbrz's comments concerning this or any other thing about the LS1 engine. He has forgotten more than I will ever know. :yesnod:
To SVO 30lb injector install???
