Need Help with FOG LIGHTS
Old Jan 14, 2010 | 10:51 PM
bdiddo's Avatar
bdiddo
Default Need Help with FOG LIGHTS
Not sure what is going on. hopefully something simple. My fogs only come on when using "twilight" setting. Same with the tail lights. Everything works only when using "twighlight" setting. Not sure what else to tell to help diagnose the problem but I need help. I was getting ready to make the HID conversion.
Thx,
Old Jan 14, 2010 | 11:28 PM
lionelhutz's Avatar
lionelhutz
So, they work when they come on automatically, but not when you turn the light switch on? Sounds like a bad headlight switch...
Peter
Old Jan 15, 2010 | 08:10 PM
Nick1's Avatar
Nick1
Could also be the "multi-function" switch, left of the steering column.
It is basically responsible for a whole host of items, and problems.
Other will probably chime in about this too.
If you need to replace it, it's not too bad a job if your used to doing your own work. Others have actually fixed it; way beyond me though.
My issues was with the main hi-beams not working. Good Luck!
Old Jan 15, 2010 | 10:43 PM
bdiddo's Avatar
bdiddo
Thanks...makes sense to be the switch. I'll see if i can fix it myself this weekend.
To Need Help with FOG LIGHTS
