First Time Vette Owner Having Electrical Problems
Old Jan 16, 2010 | 01:31 PM
Youzzi's Avatar
Youzzi
Cruising
Default First Time Vette Owner Having Electrical Problems
I purchased a 2001 Corvette Convertible from CarMax with 46k miles less then 30days ago, took it in for a pinging noise, techs didnt find anything and gave the car back, when I got home there seemed to be a greasy type residue all over under the hood, paid no attention to it and thought the mechanics made a mess.
Later in the night I started the car, and every single warning light went off, no oil psi, temp showed max, no gas, radio didnt work, windows didnt work, this morning all warnings still appear but engine wont start.
This is my first vette and I have no idea what this could be, any suggestions or advice.
Old Jan 16, 2010 | 01:38 PM
lucky131969's Avatar
lucky131969
Pics of the grease please.
With regard to the current problem, it sounds like classic class 2 serial buss shorting issue. First thing is first, check the battery cables for security.
Old Jan 16, 2010 | 01:55 PM
Youzzi's Avatar
Youzzi
Cruising
grease isnt visible by camera, its a clear and light.
is there a solution for class 2 serial buss shorting issue?
Old Jan 16, 2010 | 02:01 PM
lucky131969
Many systems use the class 2 for communication i.e radio, a/c, instruments, door controls, etc....if it comes down to that, it will take time to isolate.
Again, ensure the battery cables are secure.
Sounds like the car needs to go back to CarMax and let them fix it.
Old Jan 16, 2010 | 02:03 PM
Youzzi's Avatar
Youzzi
Cruising
I think your right, it has a 30day bumper to bumper warranty so they are sending a tow truck to pick up the car, and service will look at it on monday.
Im just trying to see what the issue is...
Old Jan 16, 2010 | 02:04 PM
lucky131969
I would insist on a flatbed! Not a tow truck. JMO.....
Old Jan 16, 2010 | 02:12 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes if you can get to them via the DIC.
Old Jan 16, 2010 | 07:27 PM
dougbfresh's Avatar
dougbfresh
1) Do not buy cars at CarMax
2) Don't expect a CarMax mechanic to fix a Corvette.
Old Jan 17, 2010 | 02:01 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I doubt their mechanics have a Tech2 or the proper knowledge to work on these cars.
Since you're already in it, maybe you can return under lemon law ?
Old Jan 17, 2010 | 03:40 AM
SJPD's Avatar
SJPD
is the battery leaking acid ?
Old Jan 17, 2010 | 03:59 PM
Youzzi's Avatar
Youzzi
Cruising
Took the car to carmax yesterday, they sent a flat bed to pick it up.
Carmax is gonna look at it monday, I bought the extended warranty (have to pay a deductible) so I will let carmax have a shot at figuring it out, if not theres a corvette specialty shop near that I can take it too.
Didnt notice any battery acid.
To First Time Vette Owner Having Electrical Problems
