Hawk pads...ceramic or regular
Old Jan 19, 2010 | 11:55 AM
SFL_driver's Avatar
SFL_driver
Default Hawk pads...ceramic or regular
I'm looking to get people's opinions on Hawk's High performance street pads and their high performance street ceramic pads. The money difference is about $10 for a pair so money really isn't an issue.
Old Jan 19, 2010 | 12:22 PM
Bowtie_Brigade's Avatar
Bowtie_Brigade
It really depends on what the use of the car is. For the street, I like the low dust qualities of a ceramic pad.
Old Jan 19, 2010 | 04:46 PM
SFL_driver's Avatar
SFL_driver
That's what I've been reading in their advertisements, but how do they compare as far as breaking? Is one more responsive? Does one break harder and faster?
Old Jan 19, 2010 | 05:58 PM
cwalsh's Avatar
cwalsh
I'm doing Ceramics on mine since I will be running ZR1 replica's. I run ceramics on my 04 GTO as well as my pickup. Hardly any brakes dust and braking is no different to me.
Chris
Old Jan 19, 2010 | 06:14 PM
AJ Powers's Avatar
AJ Powers
What if someone who doesn't normally track a car decided one day to go to the track with ceramics? At the end of the day would you have rotor damage or pads ruined, or is it just that they won't perform as well after being heated up as the regular pads?
Old Jan 19, 2010 | 06:37 PM
SFL_driver's Avatar
SFL_driver
I know hawk also makes a pad for autocross track/ street use. You might be better off using that if you are planning on doing track as well as street. I believe it's the HP plus
Old Jan 19, 2010 | 08:50 PM
BOTTOMS UP's Avatar
BOTTOMS UP
many people keep 2 sets of pad so they just swap them if they run a track for some fun
Old Jan 20, 2010 | 12:24 PM
Chris_B's Avatar
Chris_B
The Hawk ceramics will be harder on rotors when they are cold than warm. On the track they will fade, but at least they will give you some warning so you can slow down a bit. This is also true with the HPS compound.
It's all about temperature. If you stay below the maximum operation temp (MOT), you are fine. Go beyond and they fade and then start break down. I often recommend people stay on their street pads for their first few track days until they have had time to learn the track (and hopefully spend time with an instructor). Once they start to run hard enough to get the street pads to fade, then it is time to start talking about higher temp pads.
Old Jan 20, 2010 | 03:16 PM
Steve20's Avatar
Steve20
FWIW
I recently installed the Hawk ceramics on all 4 corners on my wife's Tahoe. Resufaced 4 rotors before installing. Burnished the pads as instructed in Hawk's 'bed in' procedure. REsult = the initial 'bite' or feel upon applying the brake is downright awful-she didn't know I replaced the pads till I told her. If you really need to hit the brakes hard, they will flat out stop this almost 6000 pound monster in a hurry-even engaging ABS front and rear-IMO that is one heck of an accomplishment.
If I had t do it over again, I would definately go with a different (semi-metallic) pad, as greater than 99% of all stops are not 'panic' stops.
I was going to replace these with another pad, eating the 150 bucks, but I would have to resurface the rotors again because Hawk says in normal use, pad material is transferred to the rotor and this actually helps braking
Steve
Old Jan 20, 2010 | 05:16 PM
Chris_B's Avatar
Chris_B
Originally Posted by Steve20
FWIW
One suggestion: Next time consider the Hawk LTS. It is compounded for the heavier vehicles and a completely different response curve. It has better initial bite and more capacity for higher temps as well.
Old Jan 20, 2010 | 05:58 PM
jrose7004's Avatar
jrose7004
Depends on how much brake dust you want!
Old Jan 20, 2010 | 06:27 PM
SFL_driver's Avatar
SFL_driver
Can anyone give me some comparison info between the HPS and the ceramic pad?
I think I'm leaning more towards the HPS pads just because it seems like they might break a little better than the ceramics.
Old Jan 20, 2010 | 06:35 PM
Chris_B's Avatar
Chris_B
Hawk does not release numbers, but we have seen a 10-15% reduction in friction level when moving from HPS to the Performance Ceramic. HPS does leave a bit more dust, but not excessively compared to some other pads. The HP Plus, by comparison, are very dusty and tend to squeal on the street.
Chris
Old Jan 20, 2010 | 08:01 PM
AJ Powers's Avatar
AJ Powers
Default Dust
Will the Hawk HPS pads dust more or less than stock C5 pads?
Old Jan 20, 2010 | 09:46 PM
C5XTASY's Avatar
C5XTASY
My experience has been that the HPS pads dust a lot. They do dust quite a bit more than the stock pads. That being said, they stop great. I believe the trade-off is worth it. I increased the power of the car significantly and believed I should increase stopping power, also. Mission accomplished.
Ed
Old Jan 20, 2010 | 09:54 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
I use the Hawk HPS on my C5 that I track and I love them. They will leave a ton of dust and squeal like a pig. You just need to make sure that you warm them up before any hard breaking. Good luck
To Hawk pads...ceramic or regular
