Trans Output Shaft Seal
Old Jan 19, 2010 | 02:16 PM
cgilbert23's Avatar
cgilbert23
Default Trans Output Shaft Seal
Hey guys,
Here in TX it got super cold a few weeks ago (single digits @ night) and my rear output shaft seal started leaking (where the trans meets the diff). Well, now that it has warmed back up...no more leak. I am planning on changing the seal this weekend (if my service manuals come in). Since I don't have my manuals yet, I was curious if someone could point me in the right direction as to what parts I will need to order. Just the output shaft seal? Or is there anything else. I have read alot of links about this and found lots of good stuff! But I want to make sure I get all parts ordered and have everything I need prior to starting this job. This is my dd and I would like to get it done over the weekend (don't want to forget to order a part and have to wait for it to come in). I spoke w/the local dealership and he said I need the output shaft seal and an O-ring. Am I missing something? Do I need to get any sealer or anything else from the dealer while i'm there? Part #'s would be a great help if anyone has them handy!
Thanks for your input guys! Since you decided to stop in and read...for the people who have done this in the past, any tips for a 1st timer?
Oh yeah...99 a4 coupe.
Old Jan 19, 2010 | 03:11 PM
bumble-z's Avatar
bumble-z
You do realize that you have drop your rear cradle to remove the diff fdrom the trans to install this o ring?
Old Jan 19, 2010 | 03:17 PM
cgilbert23's Avatar
cgilbert23
Yup...Ive been doing alot of research about the procedure. It's going to be pretty labor intensive, but I have some help and am confident I can knock it out. I've just been getting conflicting info about what parts I need to get.
Old Jan 19, 2010 | 04:10 PM
bumble-z's Avatar
bumble-z
Being your there in Texas, I would give LG Motorsporst a call & let them know what I was planning on doing. I'm sure they wouldn't mind giving you some tips & part #'s that you might need. I removed my diff & installed a different one by myself in the garage last spring. As you have, I too did a lot of research, before tackling. I have a manual trans, so the seal & oil ring that goes over the cover was not needed when doing my switch out. Good luck.
Old Jan 20, 2010 | 12:12 PM
Mike Mercury's Avatar
Mike Mercury
R&R info and seal part numbers:
http://mikemercury.home.att.net/342.htm
Old Jan 20, 2010 | 12:44 PM
bumble-z's Avatar
bumble-z
Mike, thanks for the info. Your such an asset to the forum!!. Keep up the good work. I bought the H/Freight scissor jack which worked out great. I used my air impact to lift & lower it.
Old Jan 21, 2010 | 09:02 AM
cgilbert23's Avatar
cgilbert23
Thanks Mike, I've read your post about this and it is one of the best write-ups available. So now that it has warmed back up here in TX the leak has stopped. I cleaned everything up over the weekend and have been watching for leaks and nothing..not a drop. I'm on the fence now about even doing the seal replacement. I know I will have to do it eventually, but it rarely gets as cold as it was when the leak started. Does anyone know if the seal or o-ring could rupture? Even if its not cold as hell.
Old Jan 21, 2010 | 09:16 AM
SearayC5's Avatar
SearayC5
Don't replace the O-Ring unless your car has some serious miles on it. I have been advised from a GM tech to simply put a small bead of black stuff silicone around the o-ring to help make a seal that won't leak. This is what was advised for colder temps.
Old Jan 21, 2010 | 11:17 PM
C5FORFUN2's Avatar
C5FORFUN2
Mine does that too when it's cold. (a little more often in western Washington) Is there any way to keep this from happening without taking it apart? Maybe trans leak stop? Don't really like the idea of a leak additive though.
Old Jan 21, 2010 | 11:52 PM
tom01ss's Avatar
0tom01ss
Former Vendor
its a job for 2 ppl i did it with the car 3 ft off the ground and a craftsman atv jack too me about 4 hrs to do whole job
Old Jan 31, 2010 | 10:41 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
It's recently been cold here, and I've noticed a leak under the rear of my car as well.
I'm getting fluid puddling right on top of my rear spring, right in the middle of the car. Then, when I back out of the garage, it drips and makes an annoying track all through the driveway. I guess I have the same leak you've described here, right? Output shaft seal?
Our cold weather won't last long, so as long as I check fluid levels and keep them where they should be, I'm in no danger am I?
Old Feb 1, 2010 | 04:00 PM
cgilbert23's Avatar
cgilbert23
You need to locate the exact location of the leak. What color is the fuild? Mine was red and was coming from where the dif meets the trans. Also, mine only leaked a small amount (the size of a silver dollar) and when backing out of the drive way there was no trail of oil. Since the weather has warmed back up, the leak has stopped. But it has gotten cold again over the weekend here in TX and it still has not leaked. The one thing I have starting doing differently since I discovered the leak is when its extremely cold (sub 32 degrees) I have been letting the car warm up longer (letting the trans fluid get to at least 70 degrees) and have had no leaks since. I know that eventually i will have to tear it apart and change the seal, but for now it's not leaking. Hopefully someone with more experience on this will chime in...good luck!
Old Feb 3, 2010 | 09:50 PM
83Camaro's Avatar
83Camaro
extremely cold? lol i drive my car in -30 below and i dont have any leaks
Old Feb 4, 2010 | 06:32 PM
bobc997615's Avatar
bobc997615
Just change the output shaft seal. I didn't have to remove the seal plate so I have a "spare" ring seal. It's not round but has a square crossection. I think GM changed the elastomer used for the shaft seal to a more compliant compound to handle the colder weather. The retail cost of the seal was $40 or so.
To Trans Output Shaft Seal
