Ughh, fog light issues ...help!!
Old Mar 5, 2002 | 09:16 PM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Ughh, fog light issues ...help!!
I have these nice PIAA fog lights and today they stoped working :( I checked the mini fuses, and replaced the mini relay in the fuse box for the fogs at $17. Still no luck. They are wired to the factory fog button, and the orange light does come on, and the relay clicks, but no lights!!
There is an PIAA adapter under the fuse box that lets you wire three wires (I think power, ground and the switch) into the fatory harness for the fogs. I checked it and looked inside, and the fuse inside is not removable but looks ok?
I just got the car last week, and without the PIAA 1100 lights its like driving with no lights at all :( C5 head lights are sorry. If any one has this system or any ideas let me know.Came with the car.
Old Mar 5, 2002 | 09:19 PM
likev's Avatar
likev
Default Re: Ughh, fog light issues ...help!! (TexCorvette)
Did you check the ground to make sure it's not lose? Bad ground can short, and also blow out the bulbs.
Old Mar 5, 2002 | 09:30 PM
TexCorvette
Default Re: Ughh, fog light issues ...help!! (likev)
The ground is tight. :( Could both bulbs go out at the same time?
[Modified by TexCorvette, 8:34 PM 3/5/2002]
Old Mar 5, 2002 | 09:50 PM
TexCorvette
they look like this: http://www.piaa.com/displayLamp.php3?inc=002x.html
Old Mar 5, 2002 | 10:20 PM
SnowyATX's Avatar
SnowyATX
TexCorvette,
I am in the same "boat" as you except I have the 1100X fogs. My PIAA relay crapped out last week....see below. My car didn't originally have fogs but I purchased the factory switch and installed from there. Here is the schematic for the 2000, presumably nothing has changed: http://temp.corvetteforum.net/c5/pew...atic_small.jpg
My setup needs both the small relay you are referring to, shown in the schematic, as well as the larger one (rectangular black box, 3 wires on 1 end and 4 on the other???) that comes as part of the PIAA harness.
I'm not sure about your install but this could be the "adapter" you are referring to.
In any case, I called PIAA today and they are more than will to replace the relay for free but they are on backorder (arggghhhh). They even offered to send me a whole new harness but stated that I would have to do a re-install due to changes in the new harness. Looks like I will have to wait for the ones on back-order as I don't want to reinstall the wiring.
Hope this helps,
Old Mar 6, 2002 | 01:30 PM
TexCorvette
Default Re: Ughh, fog light issues ...help!! (PewterC5)
That rectangular black box that says PIAA on it is what I'm talking about, I wonder if I could just use a part from pepboys insread. On backorder, goodness?
Old Mar 6, 2002 | 05:37 PM
TexCorvette
where can I get just the bulbs, or I have to order those from PIAA also?
Old Mar 6, 2002 | 08:16 PM
SnowyATX's Avatar
SnowyATX
Yep, on my system that is the PIAA supplied relay.
As far as Pepboys goes I have had the same thought. Go buy a $2.00 Bosch relay and wire it up.......I'm still debating this idea.
You should call them as your relay is potentially different than mine.....the one I have is the PL5FA model....its printed on the black box.
Richard
Old Mar 6, 2002 | 09:56 PM
SnowyATX's Avatar
SnowyATX
I believe the bulbs are from PIAA only..... but I could be wrong.
Old Mar 7, 2002 | 05:04 AM
TexCorvette
Yup, its the PIAA supplied relay. I bypassed it, and the lights work. PIAA said they will send me a new one with an external fuse. Bad news, they told me to expect 3 weeks before it shows up. Did you paint your front brakes BTW?
Old Mar 9, 2002 | 04:03 PM
SnowyATX's Avatar
SnowyATX
Yes, I painted the calipers with Krylon Red Engine Paint (I think.....). Its working great so far.....
Richard
Old Mar 9, 2002 | 04:05 PM
TexCorvette
Hey Pewter, did you have PIAA order you a relay also? There is no fee, but on back order. The new diesgn should be better, so if this happends again, I just go buy a fuse. Why didn't they think of that the first time.
Old Mar 9, 2002 | 06:49 PM
SnowyATX's Avatar
SnowyATX
Not yet...I called them but I haven't given them my name and address yet.
To Ughh, fog light issues ...help!!
