Difference in model year PCMs??????
Old Jan 25, 2010 | 12:44 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Difference in model year PCMs??????
Is there a difference between the 2000 PCM and the 2001 PCM?
Old Jan 25, 2010 | 09:30 PM
BOTTOMS UP's Avatar
BOTTOMS UP
at the minimum , the programming is different
Old Jan 27, 2010 | 09:59 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Yeah but at some I remember the connectors changing on the PCM.
Old Jan 27, 2010 | 10:25 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
99-mid03
mid03-04
wiring between 00 and 01 'should' be the same
I do NOT have firsthand experience w/ this, but have owned 98,99,00,02,03 cars, and the only diff noted on the outside was the 97/8 fins
s/w, you already know that
Old Jan 27, 2010 | 08:19 PM
TurboBerserker's Avatar
TurboBerserker
The pinouts 00 to 01 are the same (as per the service manual). I believe 99-02 are all the same pinout and all use the same PCM (frequently called a "411" pcm due to its part number).
Old Jan 28, 2010 | 11:10 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Originally Posted by Steve Doten
97/8
99-mid03
mid03-04
Thanks!
To Difference in model year PCMs??????
