Throwing on a set of headers...anything else?
Thanks guys,
Nate
Do a search for DEI Floor Tunnel Shield 24" x 21" Heat Shield Barrier
You can also buy this in larger sizes.
How about posting some pics and feedback on those headers. I don't remember seeing much on those.
So I understand that the tunnel will help with heat...but is that just from heat getting to the undercarriage or what? What is the main reason for doing it?
Thanks,
Nate
As for the Tunnel heat shield. It's hard to explain but cool as heck...There is a link to photos at the bottom:
1) Remove tunnel plate and write top on the top side of the plate.
2) Place tunnel plate over center of sheet of DEI heat shielding (adhesive backing facing up).
3) Trace outline of tunnel plate and "most" of the bolt holes along the perimeter.
4) Look at DEI material and make a free-hand line just inside all the bolt holes about 1/2-3/4"
5) Take a knife and carefully cut the adhesive backing protector along the free-hand lines you created and remove adhesive backing ONLY from the middle (see photos at bottom).
6) Place tunnel plate with "TOP" facing up, carefully over exposed adhesive backing using original tracing lines. Once lined up press onto the DEI material and press down along the entire tunnel plate.
7) Flip over and fold "wings" inward to expose your bolt holes. Trim wings down as desired.
8) Re-install tunnel plate bolts.
9) Press wings against tunnel sides to keep heat away from both the top and sides of the tunnel. You're done!!!
Here is a gallery of photos:
http://www.pbase.com/callaway/tunnel
I've done this twice and I didn't secure them in any other fashion. Mine has held for 10k miles with no issues. The material is rigid so it holds it's form once you get it pressed against the sides of the tunnel. A rubber mallet can be helpful but watch what's behind the material. I've seen some people put a couple rivets in on the ends of the tunnel plate. Although the one I did in the photos we took to a Kansas City performance shop to install. The idiot at the shop removed the backing even though you can clearly see we wrote on both sides to not remove it. He said he thought it looked better
No telling how we will get that tunnel plate out.
Torch Baron, it might be a few weeks before I find time to do the install. This weekend is packed, next weekend is national guard weekend....soooo hopefully in 3 weekends Ill be able to put them on. So you might actually beat me, but if you have any questions, feel free to throw them my way. I dont know a ton, but just like everyone else here, love to help
Nate
Great stuff
Thanks,
Nate
you will hear the pump spin sometimes, it sits below your LHS headlight
the motor looks cool w/out the AIR stuff and makes swapping plugs are installing LT's are more fun process, more fun is better
Nate
Nate
