Ebcm
Old Jan 28, 2010 | 02:14 PM
NAVY8N's Avatar
NAVY8N
Default Ebcm
Ok, I know its been beat to death with the C1214 Code but I just received my unit back from being repaired and installed last night and after resetting multiple times I still get the C1214, C1248 and the C1255. After doing some searching am I to understand that C1255 relates to the EBTCM and now I have to replace that module as well? Thanks
Old Jan 28, 2010 | 02:18 PM
lucky131969's Avatar
lucky131969
Honestly, if you still have the C1214, that needs to be resolved first.
Old Jan 28, 2010 | 02:25 PM
NAVY8N's Avatar
NAVY8N
Yeah, I was kinda hoping that the repair would take care of that but it didnt. Guess i could contact the repair guy and send it back for another look.
Old Jan 29, 2010 | 05:03 AM
trussme's Avatar
trussme
Default EBCM Repair
here's where/who you should send it:
For EBCM repair/replace
Call Brandon
877-648-7530 at ABS FIXER
or: www.absfixer.com
$150. plus UPS....warranted as long as you own it
Old Jan 29, 2010 | 12:57 PM
NAVY8N's Avatar
NAVY8N
Yeah... should have sent there to begin with. So even though I have the other codes your saying if it was repaired correctly I should still not have the 1214 or are the other two codes setting the 1214 code ? Frustrating!
Old Jan 30, 2010 | 10:23 AM
trussme's Avatar
trussme
Default not exactly..
[QUOTE=NAVY8N;1572918310]Yeah... should have sent there to begin with. So even though I have the other codes your saying if it was repaired correctly I should still not have the 1214..... are the other two codes setting the 1214 code ?
the other 2 codes are relative to a problem in your EBCM.. most likely that famous cheaped-out relay that goes bad in many oem EBCMs installed in C5s..
PM me your email address & I will email you my 14 page tutorial with photos that guides you thru solving this problem...
To Ebcm
