Not true. The 2.73 case is different and some vendors can put upgraded gears in there. The 3.15 cases can have new gears put in.
...you can still swap a different gearset (ratio) into a 2.73:1 rear differential. Finding a competent shop with the proper Gertrag tools and experience to do it is something else entirely.
...but it will probably be cheaper to just buy a used Z06 rear end if you would be happy with 3:42's
A used set can be picked up for about $500. If you have 3:15s you can sell them for almost that amount and you would be out just the labor to swap the diffs.
