gears or cam first?
Old Feb 3, 2010 | 06:44 PM
EnVmYc5's Avatar
EnVmYc5
Default gears or cam first?
For you guys that have gears and a cam if you had to do it over again which 1 would you do first? cam im undecided its a daily driver nothing to wild but gears im going to go with 4.11's.
Whats your opinions,
thanks,
Nick
Old Feb 3, 2010 | 08:17 PM
BOTTOMS UP's Avatar
BOTTOMS UP
if you have 2.73's stock , gears for sure
Old Feb 3, 2010 | 08:19 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Old Feb 3, 2010 | 08:22 PM
Blow Torch's Avatar
Blow Torch
Gears: but for a DD I personally wouldn't do 4.11.
Old Feb 3, 2010 | 08:59 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Gears. If you have an auto get 3:42s if you have an M6 get 4.11s
With the transmission ratios in my M12 (Zo6) it's like having 3.90s on a base C5.
The M12 is okay, but if I had a base car I wouldn't mind going a little more than 3:90s.
Old Feb 3, 2010 | 09:05 PM
sami85L98's Avatar
sami85L98
Agree with others and joshua is correct on all, u might be in contact with this Gm certified tech guy name rick, and he lives so close to you, check his thread.
http://www.ls1tech.com/forums/easter...ld-thread.html
Old Feb 3, 2010 | 09:34 PM
rebelheart's Avatar
rebelheart
Gears for sure!
Old Feb 3, 2010 | 09:36 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
The gears will help you now and really help with a cam. Change them first and then a cam after.
Old Feb 3, 2010 | 10:10 PM
EnVmYc5's Avatar
EnVmYc5
I should have added that my car is a base 6spd! Now I know they sell the ring and pinion gear with a bearing seal kit, is their any specialty tools that My tech would need he has done many gears b4 but not in a corvette ( IRS ). Or anything else I should purchase while im in their?
Thanks,
Nick
Old Feb 3, 2010 | 10:16 PM
NotAZO6's Avatar
NotAZO6
im thinkin 4.10s for my a4
Old Feb 3, 2010 | 11:00 PM
sami85L98's Avatar
sami85L98
4.10 would be beyond brutal, i had 3.54 on my C4 Auto, at 80 Mph rpm was 2400, now on my Z06 with M12 tranny and 3.42 gears, at 80 mph rpm is 2000, now go figure Auto with 4.10 at 80n mph......
Old Feb 3, 2010 | 11:04 PM
NotAZO6's Avatar
NotAZO6
where can you purchace 3.54 gears for the a4? or will the m12 gears work in the rearend?
Old Feb 3, 2010 | 11:27 PM
sami85L98's Avatar
sami85L98
You can buy rpmtransmissions.com and they are supporting vendors here too, M12 gears is for transmission, thats a lot of work, u need to swap only 3.42 gears in differential (also called pumpkin). autonatic cars need odometer update too after gear swap they do this thru software will cost another 100-200 bucks. ECS does also check eastcoastsupercharging.com, contact rick also and iam sure he will take care of you. Leave your transmission as is, dont need to touch this part for gear swap.
Old Feb 3, 2010 | 11:33 PM
2GOFAST's Avatar
2GOFAST
thanks,
Nick
I did 4.10s first and H/C later. No question about it - I did it in the right order. The gears are a blast and did not require the additional cost of a new clutch (like the H/C did). I also daily drive the car - during the warm months.
Old Feb 3, 2010 | 11:41 PM
sami85L98's Avatar
sami85L98
2Gofast: u have 6 spd, and he has Auto big difference.
Old Feb 3, 2010 | 11:43 PM
jrose7004's Avatar
jrose7004
Gears!
Old Feb 4, 2010 | 06:24 AM
EnVmYc5's Avatar
EnVmYc5
No my car is a 6 spd,
I live very close to ECS and since a friend of mine works their now Ive been trying to go their as much as possible but now a kid that I grew up with just opened up a shop and i want to give him some biz, as well.
Thanks everyone,
Nick
To gears or cam first?
Old Feb 4, 2010 | 08:19 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Thanks everyone,
Nick
Hey Nick, I can always send you out a ring and pinion so your friend can do the install for you. Just make sure he has all the correct GM setup tools. The C5/C6 rears are not like the old school ones and can be quite difficult to setup. Any questions just let me know.
Old Feb 4, 2010 | 11:55 AM
amidei's Avatar
amidei
If your stock clutch is good you can do a head cam package and later when you install your gear then install a better clutch. Using your stock clutch when you install a cam is good. It will take some time getting used to the feel of the cam. Why not get as much life out of your stock clutch as you can. Doing the gear and clutch at the same time is easier too.
Old Feb 4, 2010 | 11:59 AM
tail_lights's Avatar
tail_lights
Gears FTW!
