C5 z06 diy starter replacement
Old Feb 4, 2010 | 01:14 PM
mxn corvettes's Avatar
mxn corvettes
Default C5 z06 diy starter replacement
can someone point me in the right direction as far as how to change my c5 starter,i don't think it's that hard but i figured one of you guys must have done it before, thanks in advance.
Old Feb 5, 2010 | 10:49 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
disconnect batt.
mapp gas on the 6 manifold bolts
remove hpipe, if stock?
2 bolts on starter and wiring, note wiring location
simple job w/ lift
pita w/out lift and mapp gas, PB Blaster will also help
post of pm if need help
follow GM torque settings on starter bolts
note: GM had 2 different starters? or at least there was a change in bolts
I would pm 'valvegod' for a new starter
Old Feb 5, 2010 | 11:57 AM
wkndwarrior's Avatar
wkndwarrior
if its the same as my 98 coupe fairly easy, disconnect battery....drop exhaust from manifold......pb blaster and/or mapp gas a must (ask me how i know 3 broken studs later)...dont forget to unplug 02 sensors in the pipes (you'll see them)...remove 2 bolts on starter.....drop starter remove both wires on starter. then reverse procedure
i heat wrapped my new starter just as a precaution and type A++ disease, not sure if it will help but eases my mind.
i did mine without a lift but i agree it would have been much easier with lift.
one of the best things i've done....went from starter lug to sounding like a jet ....i just love starting it now!
other posts said the solenoids are bad about corrosion so after i made connections i sprayed the battery terminal red spray on the soleniod connections....again type A++ disease
good luck
Old Feb 5, 2010 | 12:45 PM
waddisme's Avatar
waddisme
To be safe, take a pic of the connections so you will know exactly how to put them back.
To C5 z06 diy starter replacement
