Removing power seat bracket from seat?!
Old Feb 5, 2010 | 02:01 PM
383c5's Avatar
383c5
Default Removing power seat bracket from seat?!
Pretty stumped on this one, anyone got any advice? Im trying to take the bracket/sliders off so I can attach it to my kirkey bracket and seat Thanks guys
Old Feb 5, 2010 | 05:36 PM
383c5's Avatar
383c5
ttt guys just need to know how to get the bracket off the seat....thanks
Old Feb 5, 2010 | 05:40 PM
FRCTony's Avatar
FRCTony
You have to remove the bottom seat skin and foam to get at the bolt heads...
Old Feb 5, 2010 | 08:38 PM
Bill Dearborn's Avatar
Bill Dearborn
Turn the seat upside down and remove the hog rings that hold the seat cover flap that is attached to the seat spring from the rear. Then cut or untie the drawstring that is used to tighten the seat bottom cushion. Once the drawstring is loosened remove the hog rings that hold the ends of the seat bottom cushion to the center part of the cushion. Do not lose the little plastic rods the hog rings circle around. Once you get all the hog rings out you should be able to pull off the seat bottom cover followed by the foam. Then you can get to the bolts.
Bill
To Removing power seat bracket from seat?!
