The car is running fine now and I read that 200,000 can be made with no problem. With my high mileage shhould I start thinking about a rebuild or new motor. With a 2000 vert what would be the best way to go. I'm only looking for around 400 hp. Do I need to have the bottom end redone if I go with h/c. I looked on the forum and I seen blown motors and guys that want high hp. But I looking for something that will last for long ride around the country.(I'm retireing) I will put headers on with B/B that are on now. Will any of the motors slip in w/o a lot of change to whatever that is needed. Do I need to change the jack shalf also because I'm on the original cluch. I don't drag race but do drive spiritedly. Thanks for the help
My car is at 160,000. I have replaced everything in the drivetrain, except the short block, which is still fine.
I bought a longblock from scoggins-dickey. The one mentioned above for 3250 shipped.
I have no idea when I will need to put it in, but it is here when I need to.
It is 405 hp, and with the add ons it will get before it goes in, it will be what I want.
Mild cam, intake/TB, underdrive pulley, headers, etc.
Depends on maintenance on the car. 159k it can still have some good mileage behind it if it was taken care of. I have seen some 80-90k cars that are in crap shape. If it is fine, then keep the maintenance up and enjoy it. These motors, if taken care of, can last a long time. 154k here on mine and it is fine. Supercharged as well. I figure when it goes, time for a low compression forged motor, but have not been able to kill this one yet.
2016 C2 of Year
2015 C3 of Year Finalist
Mileage should not dictate when a motor needs a rebuild, condition does. As others have said, if it runs well and isn't using significant amounts of oil, why consider a rebuild? If you really just want to add alot of horsepower, then a rebuild or crate motor makes sense.
thanks guys, Yes it is well taken care of and knowning it can go over 200000. I was just thinking of and up grade down the road. more or less seeing how much I need to start saving for the new rebuild or motor. I also found (after pages of reading) someone similar to my question. Thank You all for your help.
What is a "simple rebuild", and how would it compare to a "not simple rebuild". Where would one get a "GOOD set of heads"?
By simple rebuild I mean using the original block and not going crazy with a new motor, giant cam, etc, and not using forged internals. Good heads look into trickflow or afr.
I would not consider; "going crazy with a new motor, giant cam, etc, and not using forged internals" as part of a rebuild or overhaul simple or otherwise.
Your definition of "good heads" is a matter of your opinion. There are dozens of aftermarket LS heads on the market, popularity does not equate to "good".
I think the definition of good heads is a little more fact than my opinion. Look at the proven performers. Trickflows and AFR's flow, dyno, and perform at the track better much more often than others.
