Alternator AC Voltage
Old Feb 7, 2010 | 03:28 PM
93Ruby's Avatar
93Ruby
Default Alternator AC Voltage
I just noticed last night after starting the car, it took about 3 seconds for the dash lights to come up and the battery voltage was in the 11 vdc on the DIC for a couple of seconds before going in the the 12 range and eventually reaching the 13 range. While driving last night the voltage eventually came back up to about 13.8. This little incident led me to start checking the electrical system. I let the car sit overnight and tested the battery voltage and it was at 12.3 with the car off. I tested the alternator output and it is at 14.6Vdc and 31.6 VAC with the car running. Is the the AC voltage at an acceptable level? I would greatly appreciate any feedback. Thanks!
Old Feb 7, 2010 | 03:30 PM
k0ts's Avatar
k0ts
That's why too much AC!!! You've lost a diode or two... You need it rebuilt/replaced..
And I'd not start or drive the car.. All that AC might fry something else!!
