I had my car on the hoist the other day and noticed that the front wheels are alittle bit harder to spin than my 06 GTO. If i grab the wheel on my GTO and give it a Good spin it will keep spinning for about 20-30 rotations, Where the wheels on my Z06 make about 7-10 rotations and stop.
i am the 3rd owner of my Z which has 122K miles on it, (GTO has 25K miles) and im wondering if i should replace the wheel bearings?? I dont notice any Growling or humming while driving the car, but im going to beat that the tight wheel is due to old bearings.
Just thought i would get some other opinons to see what else i should check into.
While I hardly think the wheel spin test is valid, especially comparing different cars/wheels/brakes, etc.......at 122K miles.....I'd say you were due for bearings anyway.
I think it's just brake drag you are feeling when spinning the wheels. If anything it seems your Pontiac wheels spin too freely. My Z06 has 78k miles and the front wheel bearings were replaced about 10k miles ago. They spin like yours do, just a few revolutions at a time. I'd check for play and if they're good and you're not hearing any bad bearing noises, I wouldn't fix what ain't broken. BTW, mine were replaced due to a driving incident and GM paid for the new ones, so I put them in even though it turned out I didn't need them.
I'd be surprized if I could get mine to spin more than 2 or 3 revolutions. If I had to guess I'd say the 06 GTO is built with calipers that pull back more to remove more of the brake drag.
Peter
Thinking about this a little more, I think if your bearings were bad that they would spin more freely due to being worn, not less. One of the few things you never hear of being a C5 problem is wheel bearings, maybe only once in a while, and more likely cars subjected to road courses.
You can't check wheel bearings by just spinning the wheel. If they are not noisy, and if they are not loose the don't worry about it.
Check them by jacking the wheel a few inches off the ground and use a pry bar under the tire. Try to move the wheel in a vertical direction. If you feel any movement at all take a close look to see where it's coming from. It could be the bearing or ball joints.
You could try lubing the slide-pins on the front calipers. This would require removing the caliper as if you are changing the pads, then removing the slide pins buy pulling on the boot (carefully), then re-lubing the inside with lithium grease.
This will help with them releasing and not sticking.
This assumes that you do not have a sticking piston in the caliper, but if both Left and Right wheels exhibit similar behavior, it's probably not stuck.
and while you have the caliper off you can spin the hub to see if it spins more freely and/or listen to the bearings.
And your Z probably has a bigger brakes (a lot more caliper to rotor contact surface area) than your GTO.
couple weeks ago out w/the vette little snow squall just a little coating,very small upward inclineto get home slippin and slidingtraction control cutting in and out but allowed me to progress and get home active/traction lite came on along w/noise like traction cntrl cutting in and out ,next day lite out car seemed fine drove all seemed ok... my driveway has slight incline and brake off will slowly roll down driveway now needed inital clutch engagement to get going also in my area long hill which when going down will pick up a certain MPH now it picked up half of what it did.Jack up car rears spin normal fronts could spin by hand but free spin 1-2 revolutionswheels off ,visual insp e-thing looked okcracked bleeder open no residual pressure close bleeder.. pads ok...pushed caliper piston back slightly in bore both sides now ok hit brakes couple times to reseat piston and check for d dragwent 4 test ride ok3 weeks now still ok my guess...working the traction control/active handling whilst slipping and sliding into a frenzy might have something to do with it but it seems to be fine... any active hand/traction cntrl. electronic guru's out there can shine a light on this odd behavior??? HEY BILL C.can you help with this one??
You're right ,Long winded post....As Jack Webb from Dragnet used to say "Just the facts" that's what I gave.... I think this prob. may affect more cars if two guys notice same thing...if auto trans. may never know but I know this gotta cost performance,gas mileage,brakes,just making forum aware and put in all facts in case somebody can diagnose....got any ideas ?
Ditto what striper posted. My 02 Duramax with 116K won't spin three times. The push-pull method is the proper way to check wheel bearings. Depending where you put the jack, you will get a little upper ball joint wear if there is any. If you get any play, get someone to push-pull while you look. Later! Frank
