Drag Radial ?
Old Feb 10, 2010 | 08:27 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Drag Radial ?
What is the most common or preferred rim size for the C5 when using drag radials? Is there an advantage to using 17" over 18" rims? Cheaper tires? Lower gear ratio?
Old Feb 10, 2010 | 02:37 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Old Feb 10, 2010 | 02:47 PM
FourG63 97GST's Avatar
FourG63 97GST
I've done 18s DRs
I'll be switching to 17s, more effective and cheaper also
Old Feb 10, 2010 | 04:11 PM
chevylad's Avatar
chevylad
If you are serious about racing run the smallest rim you can fit. The smaller the rim the less reciprocating mass you have. You don't have to take my word for it. Pick up a magazine like GM High Performance and look what the hardcore guys are using. I see quite a few C5 vettes running 16 inch rims out back for drag racing.
I'm not a serious racer so I prefer the look of 18 inch rims. I remember an episode of trucks on TV and the guys installed a set of big 22 inch rims that took 12 feet off the braking distance. They compensated the loss by installing a set of baer brakes. I dunno, it seemed kind of pointless to me.
Old Feb 10, 2010 | 04:19 PM
lucky131969's Avatar
lucky131969
Huh, and here I always thought it was because of the ability to run slicks v/s a rim size that would clear the brakes/suspension on a C5.
Old Feb 10, 2010 | 05:10 PM
tommie's Avatar
tommie
some people use 18" rims, some use 17" and some use 16" rims. the 16" rims does require a small mod so you can use it....
are you looking for something for track only or for daily driving?
Old Feb 12, 2010 | 08:55 AM
Hvymtlc5's Avatar
Hvymtlc5
They would be for daily driving..seen so many people use the front rims......was wondering why.
Old Feb 12, 2010 | 11:03 AM
lucky131969
Main reason is, it was very hard a couple of years ago to get drag radials in 18's.
Old Feb 12, 2010 | 11:22 AM
99FRC Newb's Avatar
99FRC Newb
my DD has 305/35/18s on it (et streets) and i'm about to throw on a set of 335/30/18 nittos 555Rs. the 17's are more effective, but the 18's work pretty well for MOST applications
Old Feb 12, 2010 | 08:17 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Stock fronts: 17 X 8.5 with 275/40/17 drag radials. Your choice. I have been running this setup and have gone into the nines on it. If your a stick car, you may want more tire. All depends on what you have done to the car, and how hard you leave.
Old Feb 13, 2010 | 08:44 AM
99vetteran's Avatar
99vetteran
Mine are 315-35-18 toyo dr's
Old Feb 13, 2010 | 07:22 PM
FourG63 97GST
I personally didn't like the smushy feel I got from the 16s on the big end. I have to always "correct" the car as it went side to side. but thats also coming stock F1s, to M/T ET streets.
Old Feb 14, 2010 | 10:14 AM
robz's Avatar
robz
In theory 17's should work better because more sidewall.
But the compounds are so good these days and the vast tire selection has made the 18 equal in performance. On street car corvettes it has been proven that even a wide 18" drag radial can 60' like a racecar on slicks with todays technology.
The best thing to do is lay out what goals want to accomplish and then choose a tire to match your setup. We can help if you give us all the details of your setup and your intentions. Nitto's will last the longest as well.
If you just want them as street tires then a Nitto drag radial is a great choice. They will be the closest to a street tire and capable of 1.5x's. They are just coming out with new tires with a new compound as well and they always keep the street driving in mind. Even a Nitto road race tire will work well if you plan on higher speeds and faster turns.
Most people pick 17's because the tire is cheaper and they can can use front rims that match but like mentioned above a good 18" drag radial will hook well enough on the street and strip for most street cars within reason.
To Drag Radial ?
