Underhood Light Wire - Where to Plug In?
Old Feb 10, 2010 | 09:55 AM
tonylukes3's Avatar
tonylukes3
Default Underhood Light Wire - Where to Plug In?
I noticed that my underhood light was unplugged by the previous owner. I have the wire, but cannot seem to locate where the actual plug is from the car I've searched all over and all I could really find was that it's somewhere near the passenger side near the radiator. I looked all around there and didn't see any empty connectors to plug the wire into. The car has a Callaway Honker intake, so I wasn't sure if this is somehow perhaps hiding the connector (doubt it) or not. Any help would be greatly appreciated!
Sal
Old Feb 10, 2010 | 10:20 AM
thomastl's Avatar
thomastl
Connector should be right below where the wire is hanging. On the frame rail I believe.
Most disconnect since we attend car shows and have the hood up and don't want the light burning. It will cut off after a certain amount of time but if you open a door or do something then the timer starts over again.
Old Feb 10, 2010 | 10:24 AM
jedblanks's Avatar
jedblanks
IIRC correctly its near the pass headlight, tacked onto the frame rail by a 'push tab' or whatever it's called..
Old Feb 10, 2010 | 10:48 AM
tonylukes3's Avatar
tonylukes3
Great, thanks guys. I'll take a look at it tonight and see if I can locate it
To Underhood Light Wire - Where to Plug In?
