chirping noise from driver side?
Old Feb 10, 2010 | 08:25 PM
aris's Avatar
aris
Default chirping noise from driver side?
Within the past 1,000 or so miles, I've noticed a chirping noise that increases frequency with RPM coming from the drive side of the engine bay... unsure where specifically.
It kinda gets a little more audible as the car warms up. I did a search, and have seen the problem being diagnosed as anything from an idler pulley to PCV valve, to a bad lifter, to noisy rocker arms... so how can I check?
Info on the car;
2004 Z06
100k+
MS3, dual valve springs, and long tube headers within the past 5,000 miles
Any ideas are appreciated.
-Aris
Old Feb 10, 2010 | 11:23 PM
aris's Avatar
aris
Oh, and it has new pushrods.
Old Feb 10, 2010 | 11:26 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
it might be the belt
Old Feb 11, 2010 | 06:20 AM
Cybermind's Avatar
Cybermind
I had a chirping noise similar to what you describe and it turned out to be a worn out tensioner pulley on the accessory belt. Replaced it with a Dayco pulley and noise is gone. If I were you, I would remove the belts and verify the idler and tensioner pulleys for any noise or roughness.
Old Feb 11, 2010 | 01:51 PM
aris's Avatar
aris
Yea, I took a closer listen and I THINK it could be the tensioner. I'm gonna pull the belt off today and check. Thank's for the help guys!
To chirping noise from driver side?
