Firestone Firehawks vs. Goodyears...
Old Mar 7, 2002 | 08:02 PM
omrossi's Avatar
omrossi
Default Firestone Firehawks vs. Goodyears...
After several helpful replies and e-mails from other Forum members, it seems like most C5 owners use either the Goodyear factory tires or the Firestone Firehawk SZ50 EP RFT's. When reviewing the technical data, I found that the treadwidth is 1.8" less on the Firestones. How does this look? Also, how does this affect performance, tread life, traction, etc? Thanks, Mike. :cool:
Old Mar 7, 2002 | 08:25 PM
Anthony Cleveland's Avatar
Anthony Cleveland
Default Re: Firestone Firehawks vs. Goodyears... (omrossi)
I have had my Firestone's now for about 5k miles now. There is absolutely NO comparison. The Firestones still look brand new. They grip better. last longer, and look better. What else can I say.
But whatever you do, do not get a non runflat tire. I have had too many friends that ran out and bought super wide non run flat tires and guess what they got flats. I guess we live and learn.......
I live at 190 and Preston. Come check out the tires if you want. :cheers:
Old Mar 7, 2002 | 08:40 PM
99 Corvette's Avatar
99 Corvette
Some people say the Firestones look thin but I think they look fine. I have worn my rear tires down to almost nothing and they still grip better than the Goodyears ever did. I think they are the better runflat :cheers:
Jerry
Old Mar 8, 2002 | 12:49 AM
NRage's Avatar
NRage
I have had them on my RX-7 Gen III TT, they were great then and are still the better choice. They stick better, run quieter, and last longer! This is all added to the run-flat capability. :yesnod:
Another minor feature is the wheel protection bead.
The 'lesser' tread width is due to the 'rounder' shoulder design. If you must have the 'square' tire than the Good(?)years will have to do. :nonod:
Soooo, tell me...do these look bad? ;)
Old Mar 8, 2002 | 01:14 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Firestone Firehawks vs. Goodyears... (NRage)
I will never use the GY RF's again...I agree with all the positive responses above... the Firehawks are superior in every way that I've noticed... GO WITH THEM...You won't be disappointed :yesnod: :smash: :cheers:
Old Mar 8, 2002 | 08:46 AM
Mitch C's Avatar
Mitch C
Default Re: Firestone Firehawks vs. Goodyears... (MDL-01C5)
The Goodyears can be driven for up to 200 miles with no air pressure, the Firestones are rated at only 50 miles. The thicker and stiffer side wall and harder rubber compound is what allows the Goodyears to be driven further while flat. But is also the reason they ride harder and are noiser than Firestones, as with most things in life there are no free lunches. Good luck with your choice.
98 A4 Metalic Purple
Powerloaded
172 t.stat
Pro Torque 2400
3.42 gears
Donaldson Blackwing
[Modified by Mitch C, 6:51 AM 3/8/2002]
Old Mar 8, 2002 | 09:47 AM
KingTut's Avatar
KingTut
Default Re: Firestone Firehawks vs. Goodyears... (Mitch C)
"Mitch C" - excellant points. I think when we realize that everything is a compromise, the most helpful posts are those that point out the give and take of any decision. Too many "emotional I spent my money well responses".
For me - 50 miles is enough to still cover me as a run flat, yet improve the road noise and hard ride. If I lived out in the west, were it can take 200 miles to get to a tire repair place, I might choose differently.
Again great, informational points.
Old Mar 8, 2002 | 11:01 PM
Mitch C's Avatar
Mitch C
Default Re: Firestone Firehawks vs. Goodyears... (KingTut)
King Tut, you have the right idea, both tires are good when choosen by the right person for the right reason.
Old Mar 9, 2002 | 12:52 AM
SteveL2's Avatar
SteveL2
My biggest priority was getting rid of tire noise. As a result, the Firestones were well worth it. I had them on my C4 and liked them so much that I put a set on my C5 the first day I bought it.
I agree that they look smaller on the car. For me, that's no big deal. :)
Old Mar 9, 2002 | 01:24 AM
aces's Avatar
aces
Default Re: Firestone Firehawks vs. Goodyears... (SteveL2)
I prefer non-runflats and carry a pump with a repair kit. In the last 20 years and thru 3 vettes I've only had to use it once....on my C5. Maybe it's habit but I've fixed a few womens tires and found them all to be very grateful. :cheers:
Old Mar 9, 2002 | 02:55 AM
wottogo's Avatar
wottogo
I read several tire posts in the Z06 and the wheel-tire sections. The Z people are putting a lot of miles on the stock non-runflats and gaining all the benefits. If you are prepared for a flat it doesn't seem like such a big threat. I'm liking the difference it made on my Coupe, and I like the look as well.
Old Mar 9, 2002 | 04:02 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Firestone Firehawks vs. Goodyears... (wottogo)
Actually, that's a very valid point, sir :yesnod:
... one I will definitely consider when it's time to replace my tires next time-- :cheers:
Old Mar 9, 2002 | 10:03 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The runflat/nonrunflat issue provokes as much emotion as radar detectors.
One other point- the runflats are somewhat safer for most applications: you don't have to worry about being stuck in an unsafe area with a flat tire, and a blowout at high speed is usually a non-event with a runflat.
Mitch C said it right; pick the right tires for YOU.
Old Mar 10, 2002 | 03:17 AM
silversport's Avatar
silversport
Default Re: Firestone Firehawks vs. Goodyears... (Gearhead Jim)
...and that, sir is what this stimulating Forum is for...excellent!!! :D :cool: :cheers: :chevy :seeya
Old Mar 10, 2002 | 04:40 AM
jorex's Avatar
jorex
Default Re: Firestone Firehawks Z rated rather then Y
Is anybody unning these Firestones over 150 MPH? They are only Z rated rather than Y rated. Are they good for short runs over 150? Maybe it is no big deal so long as they aren't run for long periods over 150. Anybody know if this is really an issue for amateur performance driving?
To Firestone Firehawks vs. Goodyears...
